June 30, 2014, 07:05 |
Dam break simulation
Lakshmi Sundar
Rep Power: 11 |
I'm trying to plot Depth of water vs time in a particular plane(almost in the center of the domain). Can anyone explain me with procedure involved. I also wanted to know what is the output i get when i use areaInt(Water.Volume Fraction) function (i.e like if we use area function we get an output of l*b).
Thanks in advance |
June 30, 2014, 08:46 |
Rep Power: 143 |
If you do areaInt(Water.Volume Fraction) over your plane you will get the area of the plane covered with water. Divide it by the plane length and you will have the average depth.
July 1, 2014, 01:16 |
Lakshmi Sundar
Rep Power: 11 |
Thanks a lot
How to delay releasing the water column in dam break case? | Pirlu | OpenFOAM Running, Solving & CFD | 3 | June 4, 2014 23:04 |
Dam break simulation water level decreases over time | aarratia | FLUENT | 1 | May 9, 2014 10:25 |
changing position of Water column in dam break | vivek070176 | OpenFOAM | 2 | June 29, 2011 06:55 |
interDyMFoam mass conservation issues - dam break tutorial | kmooney | OpenFOAM | 5 | June 1, 2010 14:23 |
simulation of dam break | moh | Main CFD Forum | 5 | September 25, 2002 18:19 |
