July 8, 2014, 08:58 |
Result output chart
Ya
Rep Power: 12 |
Hi can anyone tell me how to output result chart using normalised figures?
I got result chart for the flow velocity over a flat plate (i.e. velocity-length of flat plate) but I would like to normalise the result (i.e. streamwise velocity/bulk velocity-length of flat plate/height of the flat plate). But I have no idea to adjust the output.... |
July 8, 2014, 16:57 |
Erik
Rep Power: 23 |
You have to create an "expression" which mathematically defines what you want to plot. Then you plot this expression on your chart.
Sometimes if it gets too complex or involves remote variables, you can export the data and do it in excel. |
July 9, 2014, 02:31 |
Marcin
Rep Power: 13 |
Other way You can export your data of the chart to excel
July 9, 2014, 09:32 |
Ya
Rep Power: 12 |
But the expression edited by myself is not included in the Chart>X Axis>Data Selection>Variable...How do I add my expression there? Thanks!
July 10, 2014, 18:47 |
Erik
Rep Power: 23 |
Checkmark the custom data selection box?
It is not a variable, it is an expression. If you need sa variable define one based off your expression. |
How to display the whole result of a periodic model via one period result? | dixylo | FLUENT | 2 | February 23, 2012 04:11 |
Questions about data output | aki_yafuji | OpenFOAM Running, Solving & CFD | 3 | September 9, 2010 01:59 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
[Other] Output Format of MetaMesh | t42 | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2007 04:28 |
Problem in Result of the pressure coefficient | Ken Choi | Main CFD Forum | 2 | March 15, 1999 04:15 |
