August 14, 2014, 08:42 |
Creating A "CFX Ready to Run" File
Arash Ghorban Nia
Rep Power: 11 |
Hi
I have a high performance PC for numerical analysis in laboratory. Is there any way to make my simulation ready for run at home and just run it in laboratory. I use a network software for remote control of the PC from home and it's hard to set up simulation on CFX using remote control softwares. So if there is any simple way to import a file and click the run button please inform me about that. Does case & data file work on CFX like Fluent? Is there similar ways for this issue in CFX? Thank you. |
August 14, 2014, 11:01 |
Dave
Rep Power: 14 |
Do you have CFX on your home PC? If so you could do all of your pre-processing at home and write a solver input file (.def I think) once you're finished. Then you can log in to the laboratory PC remotely, transfer the solver input file and run the analysis. Good luck, Dave |
August 15, 2014, 15:01 |
Arash Ghorban Nia
Rep Power: 11 |
Thank you for your advice.
def file(CFX-solver manager input file) is created in this directory: C:\Users\PC-PC\Desktop\A06_files\dp0\CFX\CFX It is possible to import this file directly to CFX-pre using "import case" option, then simply start cfx-solver manager and run the simulation. |
August 19, 2014, 04:34 |
Matthias Voß
Rep Power: 20 |
you can run the case like that BUT you break the connection to the wb-project. in other words - use the wb for creating the *.def and re-import the *.res for post-processing. Also keep in mind, that you cannot do a parametric study this way (at least not as easy).
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
