Rep Power: 15 ![]() |
Dear All,
Im trying to check the velocity profile when I have 2 nozzles facing each other at ang angle of 30 degrees or so...wanted to know if there is a resultant intersecting streamline (straight, curved or whatever it is called) resulting from that high velocity of air facing each other. How to set this up in cfx? Just have a small model so 3D is ok. If you have some links for references, its very highly appreciated. Thanks guys! ![]() ![]() |
Rep Power: 143 ![]() ![]() ![]() ![]() |
Sounds simple enough in concept. But don't forget CFD is always more complex than first glance - things like compressible flow or turbulent mixing/jet impingement could make this very tricky.
For a guide of how to set up basic simulations have a look at the CFX tutorials. |
LES and TKE calculations | MST | Main CFD Forum | 3 | May 30, 2016 06:26 |
how to compute relative velocity from absolute? | spk | Main CFD Forum | 3 | July 9, 2010 08:42 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Convection velocity of Coherent structures | Jongdae Kim | Main CFD Forum | 3 | February 5, 2002 04:04 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
