August 25, 2014, 12:28 |
Radiation modeling in parallel runs
Aleksei
Good day!
Help me to solve the following problem. Solve the simulation of heat transfer between solid regions, include a set of closed gas regions are transparent to radiation. In two of these regions is modeled turbulent flow in the other - laminar flow with zero initialisation vector components of the speed and pressure. Gas regions with flow are in separate domains, and all gas regoins without flow are combined into a single domain and are associated with solid domains by GGI interfaces. In gas domains modeled radiation DTM (Surface to Surface). Physical model of fluid domains - ideal gas. Simulation is considered in parallel run with the pre-prepared par-file with EP "rad data in par file = true". Up to 40 partitions the borders of gas domains appear unphysical areas with the apparent high values of the wall radiative heat flux, leading to non-physical temperature rise in these areas up to 15000K. Different types of partitioning (ORCB, RCB, DRCB, MetisRec etc) to a positive result does not lead. Parallel run is considered on a cluster running OS Linux. Solving this simulation without radiation such nonphysical effects are absent. I would be grateful for any help with solving this problem. Thank you. |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 07:51 |
P1 Radiation Modeling in CFX | i0409013 | CFX | 0 | November 11, 2013 22:12 |
Radiation modeling | rathish | FLUENT | 0 | October 1, 2010 01:16 |
Radiation modeling | rathish | FLUENT | 0 | September 29, 2010 23:27 |
Radiation Modeling | Raju | CFX | 0 | July 5, 2005 05:50 |
