Specific heat capacity zero pressure 4th order polynomial for air |
Rep Power: 13 ![]() |
Hello there, recently I tried to create a model of air based on several data I gathered from the net. But I was unable to find the coefficients for the 4th order polynomial for specific heat capacity.
I tried to enter coefficients based on curve fitting that I did to a table of Cp vs temperature and it turns out that the specific heat ratio in the solver is almost equal to 1 with STP boundary conditions, so I guess that I may have entered the wrong coefficients. Does someone here actually have the coefficients ? Or where could I find it ? Thanks in advance. |
Erik
Rep Power: 23 ![]() |
You have to divide by the gas constant. You also use Cp0 (zero pressure) not Cp.
See the documentation for more details. |
Alright I'm gonna give it a try.
Polynomial coefficients for specific heat of Ideal gas | avi031 | Main CFD Forum | 0 | November 11, 2011 00:28 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Cn specific heat capacity changes with Temperatur? | lightgas | CFX | 4 | July 7, 2006 06:51 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
