November 24, 2014, 06:00 |
CEL function
I'm written two different equations in the expression panel and the solver can't execute then due the X variable reporting the following error: Only arguments that consist of a single recognised variable name are supported by the solver. Equation1 = areaInt_x(Absolute Pressure * X)@surface Equation2 = X * areaInt_x(Absolute Pressure)@surface Someone could help me? Thanks. |
November 24, 2014, 08:30 |
Rep Power: 32 |
Unfortunately, the ANSYS CFX Solver does not support such expression. CFD-Post does support it though.
You can workaround such limitation by creating an additional variable = x * Pressure, and later used your new AV into the areaInt_x(AV)@Boundary expression.. |
November 26, 2014, 07:40 |
Thank you very much for your help.
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Passing Values in Multiple points by 1 CEL Function | Araz | CFX | 0 | May 5, 2011 16:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
