November 26, 2014, 05:20 |
Default Units CFX ( K and C)
ahmad bakri
Rep Power: 16 |
Hi All,
Now CFX always use K generally as a default option to view temperatures in both post and solver. I know how to change a certain plot in post from K to C. The question I have is how to set that for the solver ( for user points) and even when I run a session file that measures temperatures at different locations of my model it always show in K. Now Under CFX post--Options---Solution Units I found that the Temperature is set to K. Does anybody know how to change that to C?? Regards |
November 26, 2014, 08:47 |
Rep Power: 32 |
Unfortunately, that is not supported by the ANSYS CFX Solver.
CFD-Post only changes the temperature units for display, and it has special handling for temperature differences, while the solver needs a consistent temperature unit for calculations of all sorts. Using absolute temperature avoids the confusion of when 1 [K] is 1 unit of change or 1 absolute unit. |
November 26, 2014, 11:09 |
Erik
Rep Power: 23 |
One way to do it would be to make an expression (TemperatureC) = Temperature + 273.15[K]
Then display this expression instead of Temperature. |
CFX Boundary Conditions Will Not Decouple | samuelhund | CFX | 1 | December 11, 2012 16:01 |
CFX output units? | matwav | CFX | 2 | March 23, 2009 03:20 |
Water pump OpenFOAM 15 ANSYS CFX 110 comparation | waynezw0618 | OpenFOAM Running, Solving & CFD | 39 | March 5, 2009 12:57 |
cfx default values for coeffients of k-e model | Mike | CFX | 0 | July 25, 2006 09:50 |
is "double precesion output for cfx" default? | charles | CFX | 3 | May 17, 2006 14:40 |
