December 2, 2014, 00:07 |
FSI- Negative Pressure
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I am doing FSI modelling in an artery. I find the deformation of the artery wall a bit strange and non-physical. The fluid pressure waveform at the inlet of the model is attached here. The artery wall gets expanded when the fluid pressure is positive and then it gets compressed when the fluid pressure is negative. I am completely confused why the artery wall gets compressed when the fluid pressure is negative? Is this behavior physical? Thanks for your help. AshtonJ |
December 2, 2014, 00:52 |
Rep Power: 143 |
This can happen if you have inertial effects, either in the fluid or the vessel wall.
December 2, 2014, 01:31 |
Ashkan Javadzadegan
Rep Power: 16 |
Thanks Glenn.
So, if the compression is due to the inertia force, then it should only happen in 2 way FSI, not one way FSI because in one-way FSI, only fluid pressure is transferred to the wall, am I correct? In addition, based on my results the amount of the vessel compression is approximately same as the amount of the vessel expansion. Should the expansion percentage be greater than the compression percentage? |
December 2, 2014, 17:45 |
Rep Power: 143 |
Yes, if the wall has mass/inertia than you need two way FSI to get that to affect the flow.
Also I note your initial post says "I am completely confused why the artery wall gets compressed when the fluid pressure is negative? Is this behavior physical?" - isn't it the expected behaviour that the wall compresses when the fluid pressure is negative? |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 14:31 |
