December 4, 2014, 08:19 |
#21 |
Rep Power: 32 |
There is nothing wrong with mesh inflation at interfaces. In fact, the use of mesh inflation is always a good thing if by any chance the flow comes at a steep angle crossing the interface with large gradients across the interface.
Generally, mesh inflation is a technique to minimize numerical errors in areas where steep gradients exists normal to the surface. If you are certain the flow comes at a reasonable angle at the interface, and the gradients are gradual across it, you do not need inflation. |
December 4, 2014, 09:33 |
#22 | |
davide basso
Rep Power: 14 |
Considered the position of the interface I'd probably spend some time trying to have conformal meshes across the interface (1:1 interface as called in CFX ) |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
