March 9, 2015, 18:40 |
Vertical Velocity at results
ki
Rep Power: 11 |
I am trying to read vertical velocity data of the monopile foundation of wind turbine in results but probe seems to only show velocity not vertical velocity. When i plot the contour of velocity u or w, it only shows in the contour legend and max and min value. How can I get the exact value of vertical velocity at the bottom of the monopile structure?
Thank you for your help! |
March 10, 2015, 04:06 |
Rep Power: 143 |
Use a probe to put the sampling point exactly where you want it. Then use the function calculator to extract the value at that point.
vertical velocity |
Comparing Air numerical results with water experimental results | cristian2009es | Main CFD Forum | 1 | July 2, 2014 18:11 |
velocity in a specific point in cfx results | ja.maldonado1187 | CFX | 1 | February 13, 2013 19:58 |
Results from a software for CFD that uses FEM | HectorRedal | Main CFD Forum | 0 | January 19, 2011 10:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
how to print the results from CFX-4.2 | cfd_99 | Main CFD Forum | 5 | June 21, 1999 09:23 |
