March 20, 2015, 06:01 |
Naming the domain FLUID
Thomas MADELEINE
Rep Power: 11 |
it is not really an error but I am quite curious about this...
In CFX-Pre, when I want to create a new domain every thing look normal with some random names (I tried domain 1, domain 2, fluid, fliud and FLIUD). But when I want to create a new domain named FLUID CFX open a new tab to create the domain but this tab is blank. All other tab to create a domain (no matter the name is) after this will open a blank tab. If you close CFX and re-open the .pre you were working on every thing return to normal (I use WorkBench so not sure for all the save before exit things). I tried to attach an image of the blank tab, I don't know if it will work. So this is not really a problem, I just have to avoid the domain's name FLUID, but I am quite curious on the reason of this bug. If anybody know what is going on here, I will be really pleased to learn more about that, thanks. |
March 20, 2015, 21:24 |
Rep Power: 32 |
Bizarre behavior with FLUID and FLUID DEFINITION in R15.
Tried it in R16, and it cannot be reproduced, i.e. it seems fixed. |
March 24, 2015, 07:27 |
Thomas MADELEINE
Rep Power: 11 |
I currently use the R15. I was told there are interferences with a protected name inside the program.
thanks for your help |
[DesignModeler] Extracting fluid domain for a compressor | supermanks | ANSYS Meshing & Geometry | 11 | June 8, 2015 10:14 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
Theory behind the solid domain rotation in fluid using Bets property | Riken | CFX | 0 | October 28, 2009 09:51 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
