Radial Equilibrium
Old   March 25, 2015, 00:58
Default Radial Equilibrium
MissCFD is on a distinguished road
I simulate one passage of stay vane and guide vane and one runner passage. Normally, i use an average static pressure in outlet (located at a reasonable distance below the runner) in order to allow to the pressure profile to vary but i would like to know the context in which a boundary condition of radial equilibrium is used ?
Also, if i put a boundary condition of radial equilibrium and that this is not the case in reality, this will involve a specific case of this condition that is dp/dr = 0 meaning constant static pressure. Is that right ?
Moreover, I read on this post (http://www.cfd-online.com/Forums/cfx...ressure-2.html) that the radial equilibrium theory is only valid in the blade passages but it's wrong no ? For me, it's only valid upstream and downstream of the blade passage because all transport in radial direction are rightly done in this region.
Thank you for your help
MissCFD is offline   Reply With Quote
Old   March 25, 2015, 17:49
Nobody can help me ?
Radial Equilibrium Pressure Distribution Ema40 FLUENT 1 November 12, 2014 17:52
new radial equilibrium pressure BC for turbomachinery Jonathan OpenFOAM Programming & Development 8 January 6, 2014 21:01
Radial Equilibrium pressure BC sivakumar OpenFOAM Running, Solving & CFD 5 September 25, 2013 09:40
Paper Radial Equilibrium apoorv Main CFD Forum 0 February 18, 2011 06:01
use of radial equilibrium press. in 2 phase flow James Willie FLUENT 0 May 2, 2005 11:26
