March 28, 2015, 09:04 |
problem with time step???
Hydreaulic structures
hi every one
i runned model with 300 time steps,for high computation time i stop run and shut down my system, now i want see movement water in plane that defined, unfortunately my first time step dispalyed of 254 to 300, how i bring From the beginning? Is there a way? |
March 29, 2015, 05:28 |
Rep Power: 143 |
The results for each time step exists as separate files. If you can find the files for the earlier time steps then load it and it should work fine. If you cannot find the files then they are lost and you will have to rerun the simulation.
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
