March 29, 2015, 16:38 |
Turbulent viscosity
Rep Power: 11 |
I would like to better understand how turbulent viscosity is generated by k-epsilon turbulence model.
Can I say that the higher mean velocity gradient are, the more the k-epsilon model will product turbulent viscosity ? |
March 29, 2015, 18:17 |
Rep Power: 143 |
Yes, higher mean velocity gradients will result in more turbulent production which in general leads to more k which results in higher turbulent viscosity. But this is a gross simplification and ignores lots of important other effects.
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 10:02 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
