March 31, 2015, 03:26 |
variable inlet BC
Jiri
Rep Power: 13 |
I d like to set the characteristic of the pump as an inlet boundary condition of a pipe system. The characteristic of the pump is known Q=f(dp) - mass flow is a function of pressure gradient. Pressure gradient is evaluated during the computation between inlet and outlet of the pipe system and this pressure is given back to the equation Q=f(dp) as an inlet boundary condition.
The problem is that in each iteration the dp is changed which leads to oscillations. It would be helpful to prescribe each 10 iterations dp=konstant. So dp would be changed only after the 10 iterations (and mass flow would be stabilized according to the equation Q=f(dp)). Cause if the dp is changed in each iteration the mass flow Q is unable to achieve the value given by the equation. However I cant find any way to keep any variable constant for 10 iterations. Any ideas? |
March 31, 2015, 05:35 |
Rep Power: 143 |
Don't forget you can also specify this as dp=f(Q). So you can use pressure boundaries and have the pressure gradient a function of flow rate. Worth a try, it might be more stable.
I do not know of a nice way to access historical values of CEL expressions. Probably the best way of doing this is with user fortran. |
March 31, 2015, 06:00 |
Jiri
Rep Power: 13 |
Yes, that is another but equivalent possibility. Nevetheless thank you. Allowing recursion in expressions would sort out such difficulties.
March 31, 2015, 07:00 |
Thomas MADELEINE
Rep Power: 11 |
creating recursive variable is quite stable (i have used some during a while) but here the system is quite tricky...
I was thinking of something with a counter (+1 at each timestep), a clear signal (when counter reaches 10) and a single step function in your expression of Q. But there was quite some problems to determine which expression or additional variable was refreshed first. |
April 3, 2015, 02:00 |
Jiri
Rep Power: 13 |
Yes, the idea of the counter is on the front burner, I was trying to create a counter for the expressions, but the problem always ended by the demand on recursion. I ve already found some topics about additional variable but was not able to reasonably apply it. The possibilities of the additional variable seem to be quite limited. Can you give me please any clue how to use an additional variable as a recursive value?
April 3, 2015, 03:46 |
Thomas MADELEINE
Rep Power: 11 |
i used quite a while ago.... from what I remember:
the additional variable are calculated at each time step (don't know if it is before or after expression) EX expression AV additional variable EX counter = AV Counter AV Counter = EX counter + 1 normally it should work... I will search if I find my old work to help... |
April 14, 2015, 05:04 |
Jiri
Rep Power: 13 |
I returned to this issue and I am still not sure whether this is feasable. Lets say the mass flow given at the inlet is an expression:
if(each tenth iteration, Q=f(dP), constantQ) *note:each tenth iteration can be writen as int(Curent Iteration Number/10) = Curent Iteration Number/10 Q=f(dP) is no problem. But constantQ should be the additional variable. ConstantQ must be a function of an expression which gives the new value only at the tenth iteration. The trouble is that "if" statement requires also false variant. The aim is actually prescribe that if each 10th iteration is not achieved constantQ = constantQ... moreover you need an expression to initialize it.. cannot figure it out. |
April 14, 2015, 06:06 |
Thomas MADELEINE
Rep Power: 11 |
I would choose an step function to avoid the ifnot
something like 10iteration = current iteration number - int(current iteration number/10)*10 Q = step(10iteration-9.5)*functionQ(dP) + step(9.5-10iteration) * Q if you want to avoid a direct loop you have to create an additional variable constantQ, initialize it with a run (2 timestep are enough) and then do something like: constantQ = Q Q = step(10iteration-9.5)*functionQ(dP) + step(9.5-10iteration) * constantQ I think this should work |
April 14, 2015, 09:47 |
#9 |
Jiri
Rep Power: 13 |
Thank you very much for your suggestion. However I came across the following caution:
The parameter 'Mass Flow Rate' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/BOUNDARY:inlet/BOUNDARY CONDITIONS/MASS AND MOMENTUM' is defined to be "Single Valued" but it depends on the following field valued variables: , QmAdVariable. I prescribed the massflow rate to be the QmAdVariable. QmAdVariable is defined according to the above mentioned equation QmAdVariable = step(10iteration -9.5)*functionQ(dP) + step(9.5-10iteration) * QmAdVariable. Even if I used another expression Qmm = QmAdVariable, the caution is still the same. It seems you cannot set additional variable as a boundary condition...The dimensions are fine as I debugged it. |
April 14, 2015, 10:27 |
#10 |
Thomas MADELEINE
Rep Power: 11 |
Well it is only a caution... does this run anyway ?
Sorry I didn't made myself clear. I would set the equation in a expression (Ex) and only use the additional variable (AV) to avoid the warning of recursivity: AVconstant Q = Ex Q Ex Q = step(10iteration-9.5)*functionQ(dP) + step(9.5-10iteration) * AVconstantQ You can use the expression to define your inlet. And make sure this system is correct by creating a monitor point to follow the evolution of your expression during the run. |
April 15, 2015, 02:57 |
#11 |
Jiri
Rep Power: 13 |
I am sorry for misunderstanding, it is not a caution it is a restriction (there is a "red cross") and I cannot run the solver.
I amended the algorithm according to your suggestion and the restriction is still the same. Obviously the boundary condition cannot depend on an additional variable which leads to an unsolveability of this problem... |
April 15, 2015, 03:56 |
#12 |
Thomas MADELEINE
Rep Power: 11 |
Ex Q is supposed to be an expression, if you use it to define the inlet you shouldn't have any problem (maybe a wanring about recursivity on expression)
Last edited by Thomas MADELEINE; April 15, 2015 at 03:57. Reason: coma is important here ^^ |
April 15, 2015, 04:56 |
#13 |
Jiri
Rep Power: 13 |
No no no, even if I use the expression EX Q as an inlet condition, the error is still presented. It seems that CFX checks the dependancy through the expressions - in case of boundary conditions CFX has problem that the expression is a function of the additional variable.
April 15, 2015, 05:04 |
#14 |
Thomas MADELEINE
Rep Power: 11 |
ok sorry I did not know that...
So can you delete the AV and use only expression ? Q = step(10iteration-9.5)*functionQ(dP) + step(9.5-10iteration) * Q You should have a warning about a expression referencing to itself... but maybe it can work... |
April 15, 2015, 05:28 |
#15 |
Jiri
Rep Power: 13 |
I of course did not know about this treason either. By deleting the additional variable and having the recursion in expression itself we get back to the original problem, recursion in an expression is problem and does not allow you to run the solver. The error is:
Bad expression value 'Q' detected in parameter 'Mass Flow Rate' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/BOUNDARY:inlet/BOUNDARY CONDITIONS/MASS AND MOMENTUM'. CEL error: A cyclic dependency between expressions has been detected while processing the expression assigned to 'Mass Flow Rate'. The cycle detected is as follows (there may be others): Q -> Q. Even if you suppress the message the solver fails. I think the ideas have just been run out, haven´t they? |
April 15, 2015, 05:42 |
#16 |
Thomas MADELEINE
Rep Power: 11 |
Sorry for not understanding before.
Well I am quite out of ideas now... I will continue to think about it but i would not expect miracle... Sorry again |
April 15, 2015, 05:52 |
#17 |
Rep Power: 143 |
User fortran.
April 15, 2015, 07:09 |
#18 |
Jiri
Rep Power: 13 |
To Thomas MADELEINE:
You do not have to feel sorry . Thank you anyway! To ghorrocks: I know you´ve already mentioned this possibility but I actually do not know how to grasp it. I went through help but I do not know how to apply it, is there any tutorial with explanation of the user fortran? |
April 15, 2015, 07:17 |
#19 |
Rep Power: 143 |
There are a few examples of user fortran in the CFX documentation. I have never tried to do something like what you propose so cannot help you in detail, but hopefully something like a user CEL function might work.
March 25, 2016, 12:25 |
#20 |
Rep Power: 11 |
Jiricbeng, did you manage to write this Fortran function? I will be grateful if someone could post example of such a routine. In my case, mass flow at inlet is dependent on output expression (Heat flux in a heat exchanger). I did it in CEL Expressions but I am getting error that there is a cyclic dependency. So, I assume that I have to use user fortran. Ansys documentation is not very helpful for a person without experience in Fortran, so I will appreciate any help. |
How can I fix a local coordinate system to the inlet | phys-zephyr | STAR-CCM+ | 3 | May 8, 2014 05:46 |
Variable Velocity Inlet magnitude and direction | Brendan | FLUENT | 0 | March 24, 2014 06:24 |
Variable Inlet | Boots Electric | CFX | 1 | December 2, 2013 16:16 |
Spatially and temporally variable inlet | cfd_user2011 | OpenFOAM | 1 | June 22, 2011 12:35 |
variable pressure at inlet boundary | Stephanie | Siemens | 3 | August 23, 2008 06:04 |
