April 30, 2015, 13:48 |
Ansys CFX and Fluent on UBUNTU OS
sunil
Hello Sir,
In my office we are having one server machine (details given below) and eight CPUs connected to it (details given below). Currently ANSYS CFD (CFX and Fluent) is running on windows operating system in distributed mode and we have a sufficient license to parallel run. Now I am planning to replace windows operating system with Linux (Ubuntu) for the server as well as connected 8 CPUs. My question is whether I have to install Ubuntu server OS on server machine and Ubuntu desktop OS on connected nodes or same OS for server and connected nodes because finally I must able to run in distributed parallel by maximum utilizing my hardware. Please suggest me if anything better than this…. Server Machine 32 core 2.00 GHz intel Xeon(R) X7550 60 GB RAM 1 TB Hard drive Connected CPUs or nodes (Total 8) Intel core 2 duo 8GB RAM 250 GB Hard drive |
April 30, 2015, 14:16 |
Rep Power: 32 |
If you are working in a industrial/commercial (not academic) environment, my advice is that you install a supported Linux platform; otherwise, you may encounter issues that will take time (money) to resolve and for which ANSYS may not be able to help you either.
Recall what you save on the OS cost, you will pay resolving unknown issues w/o any support. Perhaps you are lucky and it does work the first time around. |
April 30, 2015, 18:44 |
Rep Power: 143 |
I completely support Opaque's comment. I have got better things to do than waste my time sorting out low level dependencies in the OS when simply choosing a supported distribution would make it "just work".
But if you insist on using an unsupported distro, try this thread: http://www.cfd-online.com/Forums/cfx...x-distros.html |
May 2, 2015, 03:32 |
sunil
Hello Sir,
Thank you for your suggestions. I will be continuing with windows OS only. My head node is installed with windows server 2012 data center OS, when i run mpitest it showing Different OS index error (please see the attachment) and i am unable to launch parallel runs from this machine what could be the possible solution. (other systems are loaded with windows 7). http://postimg.org/image/u54c5wo6d/ |
May 2, 2015, 06:52 |
Rep Power: 143 |
The screen shot is from an ANSYS executable, not a CFX one. It does not tell you anything useful about CFX (that I am aware of anyway).
Read the documentation about setting up a parallel cluster. Check that serial and local parallel simulations work as well as distributed parallel. And don't forget there are many different parallel implementations (different MPI versions, PVM and others) so you can try them too. |
ubuntu parallel |
ANSYS Fluent or CFX - mixing, anchor agitator | paweld | ANSYS | 0 | February 3, 2015 03:09 |
Ask about the use of computers to simulate the fan with ansys fluent and cfx. | kornengineer | Hardware | 3 | December 15, 2014 17:21 |
Ansys CFX vs Ansys Fluent? | TheForumLord | ANSYS | 0 | June 11, 2014 09:46 |
Converting ANSYS CFX files to Fluent files | Martin S. Rasmussen | FLUENT | 3 | January 30, 2007 15:08 |
