Time Step Size and Number of Iterations per Time Step |
August 12, 2015, 11:27 |
spl
Rep Power: 11 |
Hi
I'm running a transient simulation for a radial turbine and I would like your advice on time step size and number of iterations per time step. A number of studies have used times steps range from 0.6 degrees per time step to 6.5 degree per time step but very few have stated how many iterations are used per time step. My understanding is that less iterations are required when using smaller time steps. So I have a few questions - Is there a general rule for number of iterations per time for CFX? What is the best method of judging convergence within a time step? Is it best to select a number of iterations per time step (say 20) and then reduce the time step until the transient results are consistent or is there a better approach? Thanks |
August 12, 2015, 19:31 |
#2 | |||
Rep Power: 143 |
August 13, 2015, 04:23 |
Mr CFD
Rep Power: 14 |
August 13, 2015, 06:02 |
Rep Power: 143 |
That depends on the simulation. Some are easy some are hard. But the bigger question is whether it is required for the simulation at hand. If it is needed then you have to do it regardless of it being hard.
August 13, 2015, 11:56 |
spl
Rep Power: 11 |
Thanks for your help.
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 05:19 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
