Create volume in CFX post for analysis purposes
Like Tree2Likes
  • 2 Post By Lance
Old   September 2, 2015, 09:37
Default Create volume in CFX post for analysis purposes
Nicolas
lavoz is on a distinguished road
Dear forum members,
I'm looking for a possibility to create a geometrically defined volume that I can later perform calculations on. Or to put it in other words, I want to create a rectangular cuboid within my fluid domain that I can refer to for additional calculations, e.g. calculate volume averaged properties.
So in my fluid domain, I can create a volume via locations and limit this volume in one dimension (e.g. z-dimension). However, I can't add any more limitations regarding the x- and y-dimension. Any ideas how this can be done?
I probably could create a group of iso clips from respective planes and average the results outside CFX, but this is not straight forward and not a “real” volume averaging, so I hope there is a better option.
lavoz is offline   Reply With Quote
Old   September 2, 2015, 09:44
Lance
Lance is on a distinguished road
One idea:
Make an expression defining your boundaries e.g. if(x>1[m],1,0)+if(x<2[m],1,0)+ ....
Make a variable of your expression.
Make an iso volume of your variable and plot it at value = 6
andbe and evan247 like this.
Lance is offline   Reply With Quote
Old   September 3, 2015, 11:36
Nicolas
Thank you very much for this idea, worked like a charm ;-)
Old   October 17, 2015, 03:08
vikas yadav
vikasy123 is on a distinguished road
Dear lavoz,
i am also stuck in the same problem.
could you please tell me how u have made the expression?
vikasy123 is offline   Reply With Quote
Old   April 16, 2019, 17:43
Default Can u help me out too pls
Amiya
amiyaabhash is on a distinguished road
Originally Posted by Lance View Post
One idea:
Can you please describe in detail.i am performing free surface flow with water being seperated into two halfs by an obstruction I wish to find out the volume passing through right side of the obstruction only.how can I do that?
amiyaabhash is offline   Reply With Quote
Old   December 14, 2020, 09:15
Default specific answer
jiangsu
virgilante is on a distinguished road
according to the responder above>>
eg.
if(x>-165[m],1,0)+if(x<-45[m],1,0)+if(y>31[m],1,0)+if(y<122[m],1,0)+if(z>0[m],1,0)+if(z<8[m],1,0)
this expression means mesh coordinates(x,y,z) input will be exported as 0 or 1, so that the algorithm will distinguish and chose the mash cell range(final output will be 6).
then, you will get the mesh iso-trim volume.
my first answer.
virgilante is offline   Reply With Quote
Old   July 5, 2021, 10:27
tias is on a distinguished road
The step is fine for simple volumetric shapes. What if the volume is more complex. Is it for example possible to import a bunch of stl surfaces that define a volume?
tias is offline   Reply With Quote
post processing, volume, volume averaging, volume generation
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[GAMBIT] how do i split volume or create volume surrounding pesar125 ANSYS Meshing & Geometry 1 December 17, 2013 01:07
cfx post create a chart turbodede CFX 0 December 11, 2012 09:11
