Priyanka
Rep Power: 10 ![]() |
I am completely new to cfx. I should add a composition of UO2+ZrO2 . I tried replacing the properties of some other material with this composite but I could not match the properties.
The properties are 1. Composition 2.liquidus temperature 3.Solidus temperature 4.Density 5.Specific heat 5.Fusion heat 6.Surface tension 7.Thermal conductivity 8.liquid dynamic viscosity 9.emissivity Actually it is a binary mixture and I am solving a multiphase flow Thank you |
Did you check CFX tutorials of multiphase and including New materials?
Priyanka
I didn't find them
Please provide links of PDFs or videos |
In the CFX window: Help>CFX>Tutorials>Check Tutorial number 17.
Priyanka
Thank you sir
Priyanka
hello sir , i checked out the tutorials but there is no UO2 or ZrO2 material in the catlog
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
