October 16, 2015, 13:35 |
problem in CFX solver
yaseen
Rep Power: 10 |
my project does not reach the convergence, why? how can help me?
(my project is free surface flow in spillway) http://www.cfd-online.com/Forums/att...1&d=1445016778 |
October 16, 2015, 14:47 |
Rep Power: 32 |
Your convergence looks fine for the standard defaults, RMS = 1.E-4, correct ?
What is the problem ? |
October 17, 2015, 02:55 |
yaseen
Rep Power: 10 |
no, it does not show me any results.
October 17, 2015, 05:19 |
Hydreaulic structures
Rep Power: 14 |
i dont underatsnd your mean, please explain more for solve problem.
October 17, 2015, 06:46 |
yaseen
Rep Power: 10 |
dear hamidciv the above attachment is the first iteration, which is finished run said (run completely normally ), after I did second iteration with finer mesh also the results is not acceptable (please see the attachments for second iteration) , thanks
http://www.cfd-online.com/Forums/att...1&d=1445078680 http://www.cfd-online.com/Forums/att...1&d=1445078688 http://www.cfd-online.com/Forums/att...1&d=1445078698 http://www.cfd-online.com/Forums/att...1&d=1445078707 http://www.cfd-online.com/Forums/att...1&d=1445078715 |
October 17, 2015, 14:01 |
Rep Power: 14 |
dear yeaseen wsu
if results is not acceptable, probably problem is induce of your mesh, i think your mesh is coarse. whether you control mesh charactristics? whether you doing verify in your model? whether your time is Enough for To reach steady state flow? are your boundary condition is suitable? |
October 18, 2015, 02:50 |
yaseen
Rep Power: 10 |
thanks a lot hamidciv
yes I have problem in mesh generation, but I sure my boundary condition is ok, what is time? time scale control, I choice physical time scale (1 second) |
October 18, 2015, 06:29 |
Rep Power: 14 |
dear yaseen , I thought you do transient simulation, my mean of time was enough time for reach to steday state in transient simulation.
October 19, 2015, 02:10 |
#9 |
yaseen
Rep Power: 10 |
no I did stead state simulation, but I have problem how to select appropriate time is there any law?
October 19, 2015, 04:54 |
#10 |
Rep Power: 18 |
You geometry is fairly simple, hexa mesh aligned with the flow will give you more accurate results.
October 19, 2015, 12:03 |
#11 |
Rep Power: 14 |
dear yaseen
as antanas mentioned, i also suggested doing mesh with hexa mesh, becasue it decrease number of cells and give same accurate in compared tetra mesh. about physical time scale , it better you read cfx help, in my order your time is large. good luck |
October 20, 2015, 00:11 |
#12 |
Rep Power: 18 |
I think you're wrong. In fact in Steady State simulation you should use the largest time step size which still gives you convergence (in terms of residuals, imbalances and quantities of interest), because converged steady solution doesn't depend on time step size. If converged solution doesn't satisfy your expectations, then you should check other things, like physical models that you use, boundary conditions, mesh independence and so on.
October 20, 2015, 02:35 |
#13 |
yaseen
Rep Power: 10 |
thanks a lot Antanas and hamidciv for your suggestion
October 20, 2015, 09:29 |
#14 |
Rep Power: 15 |
If you are worried about the convergence of your simulation you can additionally add monitor points in the flow and observe during calculation if the flow variables converge with the rms residuals at 1e-04. If not, lower the residual target.
October 22, 2015, 02:26 |
#15 |
yaseen
Rep Power: 10 |
dear Bazinga how to add monitor points in the flow?
thanks |
October 22, 2015, 03:16 |
#16 |
Rep Power: 15 |
Check Pre-Processor, Simulation-Flow Analysis-Solver-Output Control-Monitor.
There you are able to add Monitor Points at the different positions in the flow to observe for example the velocity and check convergence. |
CFX solver problem, ERROR #001100279 | gooya_kabir | CFX | 6 | May 24, 2018 05:15 |
Problem with the convergence of the solver | DOliveira | OpenFOAM Running, Solving & CFD | 3 | November 9, 2015 11:25 |
CFX solver problem | Lamine | CFX | 4 | June 14, 2013 17:43 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
CFX new user, problem with solver and PRE settings | Vijesh Joshi | CFX | 1 | March 13, 2006 22:42 |
