October 17, 2015, 00:09 |
Capturing Transient results in CFX
Dr Gurubasavaraju
Rep Power: 11 |
Hi sir,
I am calculating the force (Using an Expression) for each time step manually and obtaining the results. Its very difficult to obtain results for more then 100 time steps. How can obtain results in on shot. Please see attachment. Thank you |
October 17, 2015, 11:03 |
Rep Power: 32 |
Have you tried to create a time chart of "your quantititave CEL expression" vs time ?
Create Chart Select Time Chart Select Expression Write your Expression Apply If you need the values used for the chart, then use Export Chart |
October 19, 2015, 04:33 |
Dr Gurubasavaraju
Rep Power: 11 |
I got it, its worked. Saved my lot of time.
Thank you very much. Regard's Guru |
October 23, 2015, 11:45 |
anonymous
Rep Power: 14 |
You can also set up a monitor in Pre before running the simulation. This has a couple advantages.
- It tracks the monitor as the simulation runs so you dont have to its there and ready when the simulation is finished - You can easily watch your monitors while the simulation is running The biggest advantages to using monitors in transient simulations to track points or information rather than trying to look it up in post afterwards, is it will track every timestep, even if you only have it set to create output files some of the time. To watch your monitor points or pull out the information you want - Open up your solver with the results or current simulation (right click solution -> display monitor) - Click user points tab to see monitor - Can edit what you see by right clicking on the graph area or right click tab area and select new monitor to create your own charts To record information out of it, easiest way is to open tab then right click -> export plot data Hopefully this helps |
Time average results in Transient CFX Simulation | BalanceChen | CFX | 32 | September 30, 2021 13:59 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 05:57 |
Static structural Analysis using temperature profile from CFX transient solution | bhavik139 | Structural Mechanics | 3 | July 7, 2013 20:51 |
CFX results export problem ? | nasir | CFX | 2 | November 4, 2011 21:10 |
about "Presure" in CFX results | erick | CFX | 3 | July 11, 2006 11:25 |
