Propeller Thrust Method
Old   October 20, 2015, 22:19
Default Propeller Thrust Method
Aidan Bryant
Aidan.B is on a distinguished road
Hi All,
I'm attempting to calculate the thrust generated by an RC aircraft propeller and I'm wondering about my method.
I made a small cylinder around the propeller shape and subtracted it. I then made a second cylinder the exact same size, and a larger cylinder and subtracted the smalle from the large to give me two domains, the outer domain and inner domain with cylinder cut out. In CFX I set an interface between the two, input, output and walls on the larger cylinder and set the propeller shaped cut out to be a wall. I've then rotated the inner domain. My trouble is that this rotated the air within the domain, as well as the propeller walls. Is there a way that I can make the air continue its expected path until acted upon by the propeller? Have I gone about this in the wrong way.
I have looked through the rotor-stator tutorial, but as I understand, the whole stator will be rotating along with the blades, so, it doesn't quite match my problem.
Thanks in advance!
Aidan.B is offline   Reply With Quote
Old   October 21, 2015, 03:40
Maxim
-Maxim- is on a distinguished road
can you please post pictures of your settings? How did you set up your inner domain?
I would make the inner domain smaller - basically only around the propeller.
Did you use Stage interface or Frozen Rotor?
-Maxim- is offline   Reply With Quote
Old   October 21, 2015, 06:49
This is a FAQ: http://www.cfd-online.com/Wiki/Ansys...f_reference.3F
It is all good, you are just not viewing it as you expect.
Old   October 21, 2015, 18:40
Aidan Bryant
Maxim,
I've used Frozen Rotor.
I've attached the inner domain settings. The domain has a wall as the propeller, and an interface around the outside.
My force calculations on the propeller give a result in the range of 0.001 N, where I'm expecting 1-10 N. Would my method be close to what I require, or should I be using an immersed solid?
Thanks ghorrocks, that is much more like I expected.
Underwater Propeller CFD analysis with Ansys CFX Alaeddine CFX 7 March 30, 2018 01:37
The problem of unsteady state calculation of propeller static thrust. liulangdefeng2222 FLUENT 11 July 7, 2015 11:17
Propeller Thrust mahdisajjadi FLUENT 1 December 1, 2014 20:24
Turbulence inflow generation - recycling method panda60 OpenFOAM Running, Solving & CFD 15 April 25, 2013 01:34
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
