October 20, 2015, 22:19 |
Propeller Thrust Method
Aidan Bryant
Hi All,
I'm attempting to calculate the thrust generated by an RC aircraft propeller and I'm wondering about my method. I made a small cylinder around the propeller shape and subtracted it. I then made a second cylinder the exact same size, and a larger cylinder and subtracted the smalle from the large to give me two domains, the outer domain and inner domain with cylinder cut out. In CFX I set an interface between the two, input, output and walls on the larger cylinder and set the propeller shaped cut out to be a wall. I've then rotated the inner domain. My trouble is that this rotated the air within the domain, as well as the propeller walls. Is there a way that I can make the air continue its expected path until acted upon by the propeller? Have I gone about this in the wrong way. I have looked through the rotor-stator tutorial, but as I understand, the whole stator will be rotating along with the blades, so, it doesn't quite match my problem. Thanks in advance! |
October 21, 2015, 03:40 |
Maxim
Rep Power: 12 |
can you please post pictures of your settings? How did you set up your inner domain?
I would make the inner domain smaller - basically only around the propeller. Did you use Stage interface or Frozen Rotor? |
October 21, 2015, 06:49 |
#3 | |
Rep Power: 143 |
It is all good, you are just not viewing it as you expect. |
October 21, 2015, 18:40 |
Aidan Bryant
Maxim,
I've used Frozen Rotor. I've attached the inner domain settings. The domain has a wall as the propeller, and an interface around the outside. My force calculations on the propeller give a result in the range of 0.001 N, where I'm expecting 1-10 N. Would my method be close to what I require, or should I be using an immersed solid? Thanks ghorrocks, that is much more like I expected. |
Underwater Propeller CFD analysis with Ansys CFX | Alaeddine | CFX | 7 | March 30, 2018 01:37 |
The problem of unsteady state calculation of propeller static thrust. | liulangdefeng2222 | FLUENT | 11 | July 7, 2015 11:17 |
Propeller Thrust | mahdisajjadi | FLUENT | 1 | December 1, 2014 20:24 |
Turbulence inflow generation - recycling method | panda60 | OpenFOAM Running, Solving & CFD | 15 | April 25, 2013 01:34 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
