October 27, 2015, 05:05 |
Interpolation of look-up table
Rep Power: 12 |
I would appreciate if you could inform me how can I change the interpolation of a look-up table in cfx. I generated a RGP table for CO2, and I need very accurate result. I think CFX use linear interpolation for proprieties. how can I increase the order of interpolation? Many thanks in advance. |
October 27, 2015, 06:17 |
Rep Power: 143 |
Yes, interpolation tables are linear. If that is not good enough then either put more points in or you will have to write your own function, probably in fortran, to do higher order interpolation. But more points sounds easier.
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" | Jeremie84 | ANSYS Meshing & Geometry | 70 | October 25, 2017 16:03 |
Bounds error for an EOS specified via an interpolation table | cfdonlineuser | CFX | 2 | September 20, 2015 11:29 |
Problem in3D model processing | mebinitap | OpenFOAM | 2 | December 12, 2014 04:40 |
interpolation table user function not loading data properly | cfdonlineuser | CFX | 2 | November 25, 2012 19:37 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 14:32 |
