Error found when using Case.File (CFX 14.5) to run on CFX 15.0 |
October 28, 2015, 02:37 |
Machimontorn
Rep Power: 14 |
Hi Friends,
I used the CFX 14.5 case file to run on CFX 15.0, but I don't know why it did not run as the error was occurred and it was shown as follows. Details of error:- ---------------- Error detected by routine PSHDIR CDRNAM = /FLOW/GETVAR/MESH_DIR/ CRESLT = NONE Current Directory : /FLOW/ASSEMBLE/TIME-0 +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ And the reason why I want to use CFX 15.0 instead of 14.5, this is because of more expressions available. If anyone knows what is the problem caused, please let me know too. Many thanks. Cheers Mac |
October 28, 2015, 05:12 |
Rep Power: 143 |
Try loading the CFX file into CFX pre and saving it as a new def file.
October 28, 2015, 06:08 |
Machimontorn
Rep Power: 14 |
Many thanksss Ghorrocks,
I did try it but it cannot help. Could it be a problem from the grid file- What do you think? Because I used a geo.file from CFX 4.4, so I am not really sure that it can work well with CFX 15 or not. Cheers Mac |
October 28, 2015, 17:49 |
Rep Power: 143 |
The cfx file and the def file do not link to the geo file from CFX 4.4, that is all done in CFX-Pre.
You might need to remove and re-import the geo file into CFX 15. You are just going to have to fiddle with some options and find one which works. |
courant number for cfx transient run | Mike | CFX | 8 | April 6, 2006 23:48 |
Minimum number of nodes to run CFX in parallel | Rui | CFX | 3 | April 11, 2005 20:46 |
run Build Topology in IcemCFD 4 CFX | Ahmed | CFX | 3 | March 19, 2004 16:59 |
How to run CFX on the background? | David | CFX | 1 | January 19, 2004 16:24 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
