non-constant clearance for BladeGen and TurboGrid? |
October 31, 2015, 05:54 |
Hai Yu
Rep Power: 17 |
Hi, dear all,
After a few years away, I am now back to this forum, so glad to see it is still so many people there. I am now working on a Kaplan turbine with non-constant tip clearance, but I have found that I can not decide the tip clearance with a length variation from the leading point to the trailing point with my own rule. In TurboGrid, it seems that people can make a non-constant tip clearance by choosing "Profile Number" if he has a profile layer which is decided by the user himselfcan serve as the end of the blade. But however, in BladeGen, the points on a profile layer are decided by the system with a fixed ratio from the hub to the shroud, people can only change the ratio for a layer altogether, but can not change for each point seperately. So that means, I can not control the tip clearance with my own rule. Is there any solution for it? I really appreciate for any hints, thanks |
Impeller mesh with Turbogrid and Yplus results | Nabu | CFX | 4 | September 5, 2022 19:00 |
[Other] TurboGrid - problem with trailing edges ending with hub/shroud curve | TTM | ANSYS Meshing & Geometry | 8 | February 16, 2020 07:11 |
Files input for Turbogrid | Jun_Milan | CFX | 0 | July 10, 2014 23:34 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
