How to Monitor pressure at different voltages |
October 31, 2015, 12:33 |
Rep Power: 10 |
Hi guys, i have just stated to learn CFD.
Please can any one tell me how to apply different voltages to a fully enclosed component which has a heating coil so that i can monitor pressure change for any minute variation in the voltage. Right-now am able to apply one voltage at a time Best Regards |
October 31, 2015, 20:17 |
Rep Power: 143 |
CFD means computational FLUID dynamics. Voltage does not normally come into it. Can you explain what you are doing?
November 1, 2015, 00:57 |
Rep Power: 10 |
Thankyou for your reply,
Actually i am trying to see how the Gay-Lussac's law works by introducing a heating coil in a constant Volume and see the changes temperature,Voltage and Pressure. I have taken a cube of 50 X 50 X 50(mm) and introduced a heating coil having a voltage of 5V. I want to see the pressure and temperature for a minute change in voltage say (5, 5.1 ,5.5, 6 ....)V. I have learnt this application of voltage by a CFX tutorial named Heating Coil. And study the Fluid Flow. Thankyou for reply in Advance. |
November 1, 2015, 03:50 |
Rep Power: 143 |
If you are investigating the Gay-Lussac stuff (which does not involve voltage) then why not just apply a heat source. This does not require and voltage or any input other than the amount of heat to apply. Why complicate it by using a voltage source to generate the heat?
November 1, 2015, 04:16 |
Rep Power: 10 |
Thanks for replying
I wanted to study it differently by applying voltage so that i can see the pressure variation for voltage change. Its a law so it has to work no matter how i apply the heat source. I want to do this because i have considered the cube is thermally insulated from all the sides. Thankyou for the reply in Advance |
November 1, 2015, 04:38 |
Rep Power: 143 |
If you just want a power input then why not just specify a heat input? Why complicate it by generating the heat by an electric current?
And another issue - if the cube is insulated then its temperature will increase forever as you apply the power. This will not have a steady state answer. Or are you looking at the transient result? |
November 1, 2015, 07:05 |
Rep Power: 10 |
Thanks for the reply
Is there any way that i can give different voltages in steady state or i have to do it in transient? I think temperature will increase depending on the electrical resistance of the coil and the voltage applied. Answer to the first question is, i want this cube to be enclosed by another component say cube of little bigger dimensions, so i want provide electricity to heating coil so that i can generate temperature by resistance and inturn pressure. Thankyou |
November 1, 2015, 17:11 |
Rep Power: 143 |
* Use a heat source to create the heat. Do not use a voltage to generate the heat. Forget about the voltages! You are a beginner to CFD and there is no need to make thing complex by using a voltage to generate heat. Just generate the heat directly.
* If you want to do a steady state simulation (and I recommend you do this, it is simpler and quicker) you need to have a setup which actually has a steady state solution. This means heat needs to go in somewhere (your heat source) and it needs to go out somewhere. Currently you have nowhere for the heat to leave. You need to put some form of thermal boundary in to take the heat away. |
November 2, 2015, 01:26 |
#9 |
Rep Power: 10 |
Thanks for your Suggestions
I will consider them and get back. Thankyou |
