Modifying CFD-Post macro to output a time-varying expression at every timestep
Old   December 28, 2015, 15:19
Lightbulb Modifying CFD-Post macro to output a time-varying expression at every timestep
lynnathere is on a distinguished road
I am running a TBR case whose solution file contains multiple timesteps, similar to a conventional true transient simulation.
I want to output an expression that varies with time at every timestep. What I've attempted so far:
1) record a session where I load timestep=0, create a table ("Table 1"), in field A1 enter the current time ("Time"), in B1 enter the time-varying expression ("modalF" in the following text), save the table to a .csv file;
2) stop recording and modify the .cse file into a macro and impose a for loop on the timestep;
3) load the macro (pasted in the end of the thread).
This doesn't really work. The .csv file I got after running the macro has only one row with "Time" and "modalF" at the timstep=1 recorded at the first and second column.
I'm guessing my syntax on the table fields ("A$i" and "B$i") might be wrong, but I don't know what the correct syntax is or how to fix it.
Can somebody more experienced in CFD-Post macros please help? Thank you!!
# Session file started: 2015/12/28 14:23:18
# CFX-17.0 build 2015.09.01-23.36-134860
# To avoid unnecessary file pre-processing and modifications, include
# COMMAND FILE at the top of your session file.
# If it is not included, the file is assumed to be older and will be
# modified for backward compatibility.
COMMAND FILE:
CFX Post Version = 17.0
END
DATA READER:
CASE: Case trnExactTT_s1r2_02_timestep60_noHarFor_005
Current Timestep = 0
TBR OPTIONS:
Timestep Sampling = Uniform
Number of Timesteps = 240
END
END
END
!$start = 1;
!$finish = 5;
!for($i=$start,$i<=$finish,$i++) {
> load timestep=$i
TABLE:Table 1
TABLE CELLS:
A$i = "=Time", False, False, False, Left, True, 0, Font Name, 1|1, %13.7e,\
True, ffffff, 000000, True
END
END
TABLE:Table 1
TABLE CELLS:
B$i = "=modalF", False, False, False, Left, True, 0, Font Name, 1|1, \
%13.7e, True, ffffff, 000000, True
END
END
TABLE:Table 1
Export Table Only = True
Table Export HTML Title =
Table Export HTML Caption Position = Bottom
Table Export HTML Caption =
Table Export HTML Border Width = 1
Table Export HTML Cell Padding = 5
Table Export HTML Cell Spacing = 1
Table Export Lines = All
Table Export Trailing Separators = True
Table Export Separator = Tab
END
>table save=N:/tmp_cfx_projects/test.csv, \
name=Table 1
# Session file stopped: 2015/12/28 14:24:10
lynnathere is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
