December 30, 2015, 08:40 |
centrifugal pump CFD - torque
Pei-Ying Hsieh
Rep Power: 18 |
Dear CFX experts,
I simulate a centrifugal pump case using MRF - a transient case. The impeller rotates at 4000 rpm. The calculation completed successfully. I output the torque on the impeller at each time step (torque_z()@impeller). During one revolution, the reported torque_z goes from 0.01 N-m to about -0.01 N-m and increases back to 0.01 N-m. I am wondering why this is the case. Shouldn't torque in Z direction be constant? Any suggestion? Thanks! Pei-Ying |
January 2, 2016, 00:01 |
Rep Power: 143 |
Why should the torque be constant?
You are going to have to look at what it is modelling and try to work out why the torque is changing. Then you can think about whether it is realistic or not. |
January 6, 2016, 07:47 |
Pei-Ying Hsieh
Rep Power: 18 |
HI, Glenn,
It looked like the torque is almost constant because rpm is constant. the origin and rotational axis is offset from the global coordinate, hence, it is wrong to use torque_z() because it references the global coordinate. I created a local coordinate, called myCoord that fixes on the MRF axis and rotates with the MRF. Then, in expression, I define torque_z_myCoord()@impeller. Now, I am getting the torque value at each time step almost constant (very small oscillation). Hope this will help other people running similar cases. Pei-Ying |
January 7, 2016, 18:32 |
Rep Power: 143 |
Obviously you have to align the torque axis with the axis of rotation. You are going to get useless results if you don't do this.
But it is normal for a rotating machine to have torque variations against angle as blades pass stators, wakes move across blades and other similar things. How large these torque variations are vary depending on the type of machine. |
Analysis of hemolysis in a centrifugal blood pump. | ameen@cfd | OpenFOAM Running, Solving & CFD | 1 | August 16, 2016 02:57 |
centrifugal Pump Efficiency | A.farid | Main CFD Forum | 0 | March 31, 2012 07:39 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 08:00 |
CFD analysis of Centrifugal pump at shut off condition | Nitin Dewangan | CFX | 2 | February 10, 2012 18:48 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
