December 31, 2015, 06:07 |
Two-way FSI of row of cascades
beyonder
Rep Power: 11 |
This is the error i am getting. I am using cascade of 5 blades. I did the same with 5 flat plated and it worked just fine. I think there is some error in mesh quality. I have tried to improve that but still i am facing the same error. Please suggest anything to work this.
Thanks +--------------------------------------------------------------------+ | | | Interpolation of Initial Values | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Interpolator 15.0.7 | | | | Version 2014.04.10-23.00-131675 Thu Apr 10 23:23:37 GMTDT 2014 | | | | Executable Attributes | | | | single-64bit-int32-supfort-optimised-noprof-lcomp | | | | (C) 2014 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: serial run +------------------------------+------+--------+----------+----------+ | Host | Mesh | PID | Job Started | | | Part | | DD/MM/YY | hh:mm:ss | +------------------------------+------+--------+----------+----------+ | PC-5 | 1 | 6364 | 31/12/15 | 16:33:38 | +------------------------------+------+--------+----------+----------+ +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ | Real | Integer | Character | Logical | Double ----------+------------+------------+-----------+----------+---------- Mwords | 1.44 | 0.90 | 0.45 | 0.02 | 0.20 Mbytes | 5.48 | 3.42 | 0.43 | 0.09 | 1.54 ----------+------------+------------+-----------+----------+---------- +--------------------------------------------------------------------+ | Host Memory Information (Mbytes) | +--------------------------------------------------------------------+ | Host | System | Allocated | % | +-------------------------+----------------+----------------+--------+ | PC-5 | 16291.40 | 10.95 | 0.07 | +-------------------------+----------------+----------------+--------+ ================================================== ==================== Interpolating Onto Domain "Default Domain" ================================================== ==================== Total Number of Nodes in the Target Domain = 1167 Bounding Box Volume of the Target Mesh = 4.10400E-03 Checking all source domains from the source file: Target mesh is different from domain "Default Domain". +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | REDHDR: locating dataset failed: what=G/CRDVX where=ZN1/VX | | | | | | | | | | | +================================================= ===================+ +================================================= ===================+ | ****** PROBLEM REPORT ****** | |--------------------------------------------------------------------| | Subsystem: Input and Output | | Subroutine name: ErrAction | | Severity level: Fatal Error | | Error message number: 001100279 | |--------------------------------------------------------------------| | Message: | | | | Stopped in routine REDHDR | | | | | | | | | | | +================================================= ===================+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error interpolating results onto the new mesh: C:\Program | | Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\solver-pcmpi.exe exited | | with return code 1. | +--------------------------------------------------------------------+ |
January 1, 2016, 23:59 |
Rep Power: 143 |
It is not clear what the problem is. You are going to have to try some things to find out what is wrong. Try starting the simulation with no initial conditions interpolated, interpolating from a different results file and interpolating onto a different def file.
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 20:43 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
initial file for fsi modeling? | mortazavi | CFX | 0 | July 21, 2009 02:06 |
fsi | sun | Siemens | 8 | January 19, 2009 23:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
