January 5, 2016, 05:47 |
Force Calculation
nofrizal
Rep Power: 14 |
Hi guys,
My question is very basic. I read through the Ansys CFX-Solver Theory Guide but it doesn't seem to answer my question so posting on here! What is the equation used or the theory behind in CFX-post force calculation (Function calculator) for "ave(Force Z)@Plane 4" My plane 4 is a circular shape with diameter 25mm. Thanks in advance |
January 5, 2016, 18:48 |
Rep Power: 143 |
The "Force Z" variable is not often used. It is the force acting on that element face and this is not usually very useful.
the ave() function does an arithmetic average over all the element faces on Plane 4. It does not take into account the different areas of the element faces. The function you probably want is force_z()@plane 4. This avoids these problems. |
January 6, 2016, 00:10 |
nofrizal
Rep Power: 14 |
Glenn,
Thank for your response, but I think I misleading the question. What I want to know is how CFX calculated the normal force on the particular surface. What is the equation used? Thanks in advance |
January 7, 2016, 18:24 |
Rep Power: 143 |
The equation is the obvious one: The normal force is pressure * area and the shear force is wall shear * area.
January 11, 2016, 04:55 |
Maxim
Rep Power: 12 |
I wish Ansys would just define their equations, expressions and variables properly in their documentation. Thanks ghorrocks for the clarification.
January 11, 2016, 05:35 |
Rep Power: 143 |
A clarification: the force field variable is evaluated at the control volume level. That means the pressure used is from the integration points and the area is the wall surface. This can then be integrated over the whole surface to give the force on the entire surface.
January 11, 2016, 21:26 |
nofrizal
Rep Power: 14 |
Thanks Ghorrocks for the insight.
March 27, 2019, 15:22 |
Navid Mikaillian
Rep Power: 8 |
Hi Ghorrocks,
i'm wondering if you have ever used the variable "wall pressure force x/y/z"? I'm gonna give it a test to calculate force (for example in y direction) using: myForceY = areaInt(Wall Shear Y)@mySurface + sum(Wall Pressure Force Y)@mySurface I am going to check if the second term of the right hand side is equal to : areaInt_y(Pressure)@mySurface Or not. Do you have any idea in prehand? |
March 27, 2019, 15:40 |
#9 |
Rep Power: 143 |
You can do whatever you like, and exploring whether things which should be equal are in fact equal is a useful check to do. I think you will find the results are complex
March 28, 2019, 06:14 |
#10 |
Navid Mikaillian
Rep Power: 8 |
Some updates if you are interested:
having an expression defined as: myWPFy = sum(Wall Pressure Force Y)@mySurface or myWPFyAve = ave(Wall Pressure Force Y)@mySurface will cause the case crashes right away after the Solver part starts. With no useful error. More strange is that for example: myWPFyAreaAve = areaAve(Wall Pressure Force Y)@mySurface or myWPFyAreaInt = areaInt(Wall Pressure Force Y)@mySurface lets the case to run (I know they are not correct, but just to be sure the error is not coming from the variable itself). Even stranger, when I open the solved case in CFDPost then "sum" and "ave" work. I am a bit confused now. Would be great if someone knows why having "sum" or "ave" does not let the solution to go forward. |
Calculation of force in x direction - 2 formulas | WhiteW | CFX | 0 | December 10, 2015 08:36 |
Lift force and Drag force calculation | KTJ | STAR-CCM+ | 3 | April 29, 2014 08:38 |
Calculation of Drag Force per unit Length | Mohammad Faridul Alam | CFX | 4 | January 11, 2013 07:19 |
Integral Force calculation in CFX 12 - wind blade case | LittleBart | CFX | 0 | April 27, 2011 04:04 |
Force report every iteration in unsteady flow calculation | Friso Landstra | FLUENT | 0 | October 23, 2009 07:13 |
