Calculating the local time scale or reading it from available expressions |
January 13, 2016, 03:18 |
Rep Power: 10 |
I am in the process of modeling vortex generators as source terms. To do this I will apply a certain momentum in some cells. This momentum is calculated with the use of the local time scale factor, defined by the paper('A tuning free body force vortex generator model by F. Wallin') as
I'm having trouble finding a way to implement , which is the local grid size, there does not seem to be an available CEL expression like there is for the others, magnitude of velocity or speed of sound. Does anyone have any tips? Furthermore, I will need to integrate this constant together with the local velocity. That means I would need to a transient simulation, right? There is no point in integrating the local velocity in a steady state simulation I would assume. |
January 13, 2016, 05:35 |
Rep Power: 143 |
Speed of sound and Magnitude of Velocity: Variables exist for these, look in the CFX documentation in the reference guide for a list of available variables.
I don't think loal mesh size is available. You could use the cube root of the volume variable (which is the control volume's volume). But I am very wary of your function as it goes to zero as the mesh gets smaller - it is inherently mesh sensitive. This does not sound physically realistic to me. You need to integrate your function with the local velocity - what do you mean? What type of integral? Please give the equation you wish to model. |
January 13, 2016, 05:46 |
#3 | |
Rep Power: 10 |
I have found those two expressions, it's the local mesh size that I haven't found yet. Cube root might work, but then your elements would need to resemble a cube for it to be accurate. The paper gives the derivative of body force with being equal to the from the previous equation, and the others density, local velocity and the VG normal vector. So in order to implement that the body force you need to integrate that equation. Which would mean you would have to integrate the local velocity. Something to tune of |
January 13, 2016, 06:22 |
#4 | |
Rep Power: 143 |
And integrating it over time just adds to the problem. Can you explain to me how a body force can be a function of flow conditions in the past? Regardless - to answer your question: Have a look at the units of momentum source terms. That will tell you the units of the function you are looking for and I suspect will help you. Don't forget you will probably need a momentum source term coefficient as well - these are described in the documentation. |
January 13, 2016, 06:50 |
#5 | |
Rep Power: 10 |
That doesn't seem physical, but I suppose the author wants to mimic a certain affect. He states the expression comes from equating the flow tangency condition to the rate of change in the normal force. But doesn't explain what the implications of it are, as you have just shown. The units do match though, I did check those. And thanks for the tip. I have found other models, but this had one promising feature. Though I should take a more critical look at my choice now. Thanks for the help |
January 14, 2016, 03:11 |
Rep Power: 10 |
Somewhat related to this issue. Is it at all possible to obtain more geometrical information about a mesh volume (in CFX pre that is, not in the MESH environment)?
I want to check whether a line (or a point on that line) is crosses/inhabits a mesh volume. So I would need data about the grid edges but this seems unavailable, is that correct? I have managed to make a method that checks whether grid nodes are in a volume, but the latter would be preferred. I have added an image to illustrate my point a bit better. |
January 14, 2016, 04:56 |
Rep Power: 143 |
You would need to do this using user fortran. But I am no expert on user fortran so cannot help you there.
source terms |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
