January 21, 2016, 05:30 |
Modelling accoustic waves/Piezo transducer
Michael
Rep Power: 10 |
Hallo everyone!
I am facing quite a big problem at the moment modelling the acoustic waves emitted by a Piezo transducer. What I need is an accurate model that generates pressure waves propagating through a fluid medium. I first tried a momentum source term inside a subdomain but a reasonable pressure fluctuation has the adverse side effect of too high velocities. I also tried it with a sinusoidal mass source term at a wall but the net mass flow is somehow positive and not zero (thus also not adequate). If I use a point mass source the problem is that the pressure wave propagation isn't unidirectional. I then thought about a more sophisticated model which aims to model the Piezo membrane itself. So I set up a model with an immersed solid inside my fluid domain but unfortunately CFX doesn't support compressibility effects when using an immersed solid. Does anyone might have an idea how an acoustic wave can be modelled in CFX beside the models I already tried? I am grateful for any suggestions Thanks a lot in advance! M |
January 21, 2016, 17:16 |
Rep Power: 143 |
I have a colleague who has modelled piezo membranes in CFX. He used moving mesh to do it and it was very successful.
https://www.researchgate.net/publica...e_flow_control https://www.researchgate.net/publica..._jet_actuators |
January 22, 2016, 06:16 |
Michael
Rep Power: 10 |
Thanks so much Glenn! What would this forum be like without you
I was already setting up an Ansys Mutli-field code coupling case but this approach seems to be more straightforward and it looks like it does exactly what I wanted it to do I hope you have a lot more colleagues for upcoming questions in the near future M |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Question about Moving Mesh Modelling | ashtonJ | CFX | 5 | April 17, 2014 05:47 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
Unsteady modelling technique? | Carlos | FLUENT | 0 | September 26, 2008 11:37 |
