why the volume fraction for entire model is not appear |
February 19, 2016, 01:09 |
yaseen
Rep Power: 10 |
hello
the following images are my model, after 1000 iteration running, the problem is the volume fraction for entire model is not appear (I used volume rendering in CFX post) what is reasons of this??? http://www.cfd-online.com/Forums/att...1&d=1455862066 http://www.cfd-online.com/Forums/att...1&d=1455862080 http://www.cfd-online.com/Forums/att...1&d=1455862099 |
February 19, 2016, 04:32 |
Rep Power: 143 |
FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
If those tips do not help then please post your CCL (not screen shots of CFX-Pre, please). |
March 12, 2016, 11:08 |
#3 | |
yaseen
Rep Power: 10 |
March 12, 2016, 16:44 |
Rep Power: 143 |
If it is converging quickly and rapidly despite the high Courant number you should be fine.
March 13, 2016, 03:02 |
yaseen
Rep Power: 10 |
no, I said does not converged, I selected time step 0.06 s according to mesh size 0.006 mm (min) and inflow velocity = 0.03m/s, but I dont know velocity in the model entirely, so how can reduced? Courant No, or Courant No. is a reason to the simulation become non converged? thanks
March 13, 2016, 03:19 |
#6 | |
Rep Power: 143 |
My recommendation for time step size is to use adaptive time steps homing in on 3-5 coeff loops per iteration. Then the solver finds its own time step. |
March 13, 2016, 06:05 |
yaseen
Rep Power: 10 |
thanks for your recommend, based on Courant No.between (2 - 10)
March 13, 2016, 06:46 |
Rep Power: 143 |
Unless you have shown that a Courant number of 2-10 is suitable for your simulation then it is meaningless. CFX is an implicit solver and does not have a easily definable stability limit like explicit solvers do. So I recommend you do the adaptive time steps homing in on 3-5 coeff loops per iteration instead.
March 20, 2016, 13:56 |
#9 | |
yaseen
Rep Power: 10 |
Time steps option - adaptive first update time - 1s update frequency - 1 initial time step -0.03 sec min time step 0.00001 s max time step 5 s target min loops 3 target max loops 5 time step decrease factor 0.8 time step increase factor 1.06 |
March 20, 2016, 18:45 |
#10 |
Rep Power: 143 |
If that is converging every time step then it should be fine. Or is it not converging?
March 21, 2016, 05:16 |
#11 | |
yaseen
Rep Power: 10 |
note: I choose the initial time step not randomly, but by a number trials and calculation like sensitivity analysis, in my view my mesh is also good in most time steps equations of velocity (U, V, W) shows (ok not OK), I think this relates to inlet velocity B.C, as in image show i have velocity in (x,z) but for y axis (vertical) is zero. so I enter (U=0.03m/s, V=0, W=0.03m/s) is it x=U, y=V , z=W ? or I should enter value for (U & V) and W=0 thanks http://www.cfd-online.com/Forums/att...1&d=1458571969 Last edited by yaseen wsu; March 21, 2016 at 09:53. |
March 21, 2016, 17:11 |
#12 |
Rep Power: 143 |
You have done a sensitivity check on time step - good.
But you should also do one on convergence toleration and mesh size. Your convergence tolerance may be tighter (or looser) than is required, and your mesh may be too coarse or too fine. In this case, as you appear to be using a transient simulation to find the steady state answer you can probably loosen the convergence tolerance - this will help things a lot but you will need to check this before doing it. |
March 21, 2016, 22:22 |
#13 |
yaseen
Rep Power: 10 |
thanks, I know how to done senstivity analysis for mesh size, but I dont know sensitivity analysis for convergence toleration, how to done?
thanks |
March 22, 2016, 09:48 |
#14 | |
Hydreaulic structures
Rep Power: 14 |
http://www.cfd-online.com/Forums/cfx...imbalance.html hope it helps. |
March 22, 2016, 14:01 |
#15 |
yaseen
Rep Power: 10 |
thanks a lot
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Mass fraction and volume fraction | eric weddle | CFX | 0 | September 26, 2011 05:02 |
