Gas turbine engine simulation
Like Tree1Likes
  • 1 Post By spl
Old   March 16, 2016, 01:36
Default Gas turbine engine simulation
Chicklets@g is on a distinguished road
Is it possible to simulate an entire gas turbine engine in CFX without using udf?
Chicklets@g is offline   Reply With Quote
Old   March 16, 2016, 02:03
alirezame is on a distinguished road
your question is general. yes it is possible but it depends on the case.
alirezame is offline   Reply With Quote
Old   March 16, 2016, 08:08
Can we show the turbine rotating due to the combustion products?
Old   March 16, 2016, 08:14
yes it is possible by simulating transient mode.
Old   March 16, 2016, 08:37
And there's no need for udf right?
Old   March 16, 2016, 08:39
User Define Function you mean?
in simple cases no you don't need, but it depends on your case.
Old   March 16, 2016, 08:41
I want the turbine to rotate due to the impact with the combustion products..
Old   March 16, 2016, 08:44
it is possible to model this case, but first you have to know CFD and CFX in general. I recommend to study the tutorial files of the CFX first.
Old   March 16, 2016, 08:45
spl
spl
spl is on a distinguished road
It is possible to simulate the turbine operation but CFX doesn't allow fluid driven motion. So the turbine rotation would not be a result of the combustion products directly.
alirezame likes this.
spl is offline   Reply With Quote
Old   March 16, 2016, 08:48
So which software will be appropriate for my case?
Ansys CFX in my opinion
Old   March 16, 2016, 08:49
But u just said that it's not possible to show such a thing directly in cfx..
Old   March 16, 2016, 08:53
I have tried with a turbine which was rotated directly as a result of the flow. so this case seems similar and I think it would work also.
Old   March 16, 2016, 08:56
Ya that sounds similar to my case..
Old   March 16, 2016, 10:18
spl
spl
alirezame - Did you achieve this using an immersed solid approach or a rigid body and moving mesh method?
Old   March 16, 2016, 10:59
I am yet to perform the simulation..
Old   March 16, 2016, 11:28
spl
spl
I know, that's why I asked alirezame.
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 09:45
Gas turbine in CFX rahat69 CFX 4 April 11, 2014 23:44
Ideal gas v.s. Real gas for wing simulation Anna Tian Main CFD Forum 1 December 16, 2013 11:39
Sliding mesh vs MRF in axial turbine simulation Vito FLUENT 3 December 21, 2011 04:57
exhaust gas simulation jai CFX 1 November 23, 2009 04:23
