Calculate wall heat flux
Old   March 17, 2016, 06:08
Default Calculate wall heat flux
leasken is on a distinguished road
Hi! I am a bit confused on how CFX calculates heat flux at the wall. Trying to model heat transfer in a smooth duct, steady state, SST, velocity and temperature inlet, pressure outlet, fixed temperature on the walls, Air Ideal Gas. In the theory guide, Modelling Flow Near the Wall 2.8.1, it is stated that
qw =( rho cp u* (Tw-Tf) )/ T+
where T+ = 2.12 ln (y*) + B for Scalable Wall Function, SWF
and T+ = Pr y* e^(-gamma) + [2.12 ln (y*) + B]e^(-1/gamma) for Automatic Wall Treatment/Function, AWT/AWF,
where gamma and B are functions of Pr and y*.
What is u* for AWF/AWT? What is y* for AWF/AWT? If the mesh is refined, y+<1, is CFX really using AWF/AWT? If CFX is not using AWF/AWT, how is then qw calculated?
leasken is offline   Reply With Quote
Old   March 24, 2016, 02:31
Antanas is on a distinguished road
CFX always use AWT at least for eddy viscosity turbulence models. If model is not able to integrate directly to wall (like k-e) then Wall Functions is always used, in opposite case it depends on mesh (local y+) what approach will be used in particular point to obtain near wall velocity and temperature.
Antanas is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Not able to calculate wall heat flux in cfd post vikasy123 FLUENT 1 November 21, 2015 00:44
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
