March 22, 2016, 12:17 |
pressure and initial condition
hossein
Rep Power: 14 |
Hi
I am trying to simulate a close container which contains water and also simulating free surface and sloshing I have faced very strange problem. Although i have defined initial static pressure of water by ccl. [below image], when i check pressure in CFD-Post (in t=0s) the pressure distribution all over the container is constant and equal to zero. Also after progressing time the pressure is not changing in all over the cube! why it is happening? Any suggestion? |
March 22, 2016, 13:22 |
Rep Power: 32 |
You are showing the expression, but not the CCL where it is used.
Are you certain the expression is used in the correct place ? There is domain initialization, and there is global initialization. Which of the two are you using ? Hope the above helps, |
March 22, 2016, 13:49 |
hossein
Rep Power: 14 |
I have set it in global setting.
Also i tried to set initial condition in domain initialization. nothing changed and the result is same. |
March 22, 2016, 14:08 |
Rep Power: 32 |
Can you show your CCL (command language) ?
March 22, 2016, 14:37 |
hossein
Rep Power: 14 |
free surface, static pressure |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
