April 15, 2016, 07:45 |
Timescale convergence?!
Tim
Rep Power: 12 |
Hi guys,
I'm running a NACA0015 profile at low reynolds numbers (10000-1000000) with steady sst including gamma-theta transition model. I varied my timescale to become a converged (steady state) solution. But I found out, that in some cases both decreasing and increasing the timescale from my converged timestep gives me an oscillating (transient) result. My question is, does the "good" timescale maybe damp transient effects so the solution can convergate? Cheers |
April 15, 2016, 13:57 |
at what AOA?
April 16, 2016, 04:44 |
Tim
Rep Power: 12 |
AoA=0, critical Re from 10000 til 100000. above 100000 it's ok.
April 16, 2016, 06:42 |
Rep Power: 143 |
If the flow is not in the gross separated flow regime (which I suppose it is not at AOA=0), then this is probably a laminar separation bubble. They tend to be unstable and jiggle about quite a bit. If the bubble is small it probably does not affect things much but at low-moderate Re (50k-200k for many airfoils) the separation bubble can be large. It might be important in this Re range.
steady, timescale, transient |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Timescale and convergence of steady state simu with CFX | Mason liu | CFX | 7 | December 25, 2015 22:12 |
Is this convergence real? | Chander | CFX | 8 | October 21, 2011 19:59 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
