How to use the CFD results to improve our design |
May 9, 2016, 23:25 |
Frank
Rep Power: 10 |
Dear all,
Take the centrifugal pump as an example, we can get the pressure or velocity distribution of the impeller. But what's the value? And how to use these analysis to get an optimization ideal? Thank you for your attention. |
May 10, 2016, 07:12 |
Rep Power: 143 |
Yes, you can get the pressure or velocity distribution from a CFD model.
And you are very perceptive to note that CFD simulation does not automatically lead to a better product. CFD is just like an experimental test - you give it a configuration and the test tells you how good it is. The hard part is to know how to use the result to improve the design. So consider CFD as just another experiment. But to answer your question of how to use CFD results to improve designs - I will refer you to textbooks on turbomachinery design, heat exchanger design, or what ever the device you are modelling is. The design process is very different for different piece of machinery. |
May 11, 2016, 01:13 |
Frank
Rep Power: 10 |
Thank you for your answer.
I agree with your viewpoint that CFD can be seen as a numerical experiment. But basically, we spend a lot of time and resources getting the numerical results. So, we should get more useful information about our product rather than a good or frustrating test. BTW, please recommend some design textbooks on turbo machinery. I would appreciate it for your kind reply. |
May 11, 2016, 01:17 |
Rep Power: 143 |
The textbook I use is "Fluid Mechanics: Thermodynamics of Turbomachinery" by Dixon. But I am no turbomachinery design expert so hopefully some of the others who are more experienced in this area may be able to suggest others.
May 11, 2016, 03:21 |
Rep Power: 12 |
Glenn's suggested Dixon's book on Turbomachinery is probably the finest out there.. nevertheless to mention a few other good ones IMO:
Turbomachinery Performance Analysis - R.I.Lewis Principles of Turbomachinery - Seppo A. Korpela |
cfd - post, optimizaion |
Is it usual in CFD community to guarantee the results? | oj.bulmer | Main CFD Forum | 8 | November 12, 2014 07:05 |
how cfd results can be trusted in a very complex geometry | garrison | Main CFD Forum | 1 | November 8, 2014 04:13 |
Is it usual in CFD community to guarantee the results? | oj.bulmer | CFX | 0 | November 5, 2014 05:31 |
Import external CFD results into Autodesk CFD for visualisation | julien.decharentenay | Autodesk Simulation CFD | 0 | May 31, 2014 20:16 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
