Penetratig Mesh
Old   June 18, 2016, 17:12
Default Penetratig Mesh
Ferruccio Rossi
frossi is on a distinguished road
I am running a two ways FSI of a wing with CFX. In transient structural, I assigned the edge contacts (first picture) but I get a penetrating mesh (second picture). When I check the final results, I get an equivalent stress of 37 MPa about the wing root.
To verify the results, I run another simulation, but this time I use one single surface for the wing support and the wing skin (third picture). The result I get is only 20 MPa!! Why?
1. Is mesh penetration bad?
2. When I use the single surface to avoid penetration, it looks like the equivalent stress (fourth picture) is not at the wing root (where it should be). Why?
Thank you
frossi is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
