June 28, 2016, 02:01 |
RMS Mass Vapour Convergence Issue in CFX
Rep Power: 10 |
I am facing trouble in convergence of RMS Mass Vapour in CFX. All other RMS criteria are well met but RMS Mass Vapour value is 3.1E-3 and it decreases to 3E-3 after more than 150 iterations. I am dealing with subcooled boiling with constant heat flux in assembly. What should I do ? I mean could there be a way to ensure that it converges like there are under relaxation factors in Fluent. What should I do for convergence of RMS Mass Vapour in this case ? Your kind suggestions would be appreciated. Thanks!!
June 28, 2016, 05:43 |
Rep Power: 143 |
First of all: Please do not PM me with exact copies of posts on the forum. It really annoys me. If it is on the forum I will see it. I don't answer CFD questions by PM anyway.
CFX does not have the wide range of tunable Fluent has because it does not need them. The coupled solver is very robust for most applications and if it does not converge then usually it means you have a fundamental problem which cannot be fixed by simply tuning the solver constants. As you are doing a phase change simulation you should expect problems in convergence. This FAQ will give you some general tips: http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
June 28, 2016, 09:10 |
Rep Power: 10 |
When I change my working fluid to water and use higher heat flux it does indeed converge . But on the other hand for any other volatile fluid at relatively lower pressure and at comparatively lower heat flux the issue remains. What do you suggest for it ?
June 28, 2016, 19:53 |
Rep Power: 143 |
Small time steps, double precision numerics, improve mesh quality. That is a starting point.
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
issue in mass flow rate graph | amin.z | Fluent Multiphase | 0 | June 2, 2015 10:13 |
CFX overwhelming Fluent in mass convergence of boundary layer separation case | Pierre1 | FLUENT | 7 | March 26, 2015 21:43 |
Differences between CFX and OpenFOAM regarding convergence and robustness! | magjohan | OpenFOAM Running, Solving & CFD | 4 | February 26, 2015 10:26 |
CFX RMS instead of mass momentum Efficiency or Pressure ratio | Saima | CFX | 2 | June 15, 2011 12:01 |
