July 8, 2016, 09:57 |
CFX error RGP file for CO2
Select State
Rep Power: 10 |
I have to perform a calculation on a heat exchanger in which one of the fluid is CO2. I created a CFX RGP file covering the liquid, the gas and the supecritcal region of the phase state diagram. But I met one problem about CFX-solver.
July 26, 2016, 03:14 |
Yuva
Rep Power: 10 |
Hello
Are you solving the problem on one machine Windows or on Cluster platform Linux ? Did you create the RGP file by yourself or you import it from NIST ? AND you need to specify the competent name (CO2 for ur case ) of the fluid exactly as it is written inside the RGP file when you upload the file in CFX Tell me if it works windows.JPG |
August 2, 2016, 08:59 |
Select State
Rep Power: 10 |
https://www.reddit.com/r/CFD/comment...al_properties/
There is a RGP and i changed it according to my need.But there was a problem when i upload the file in CFX.And i specify the competent name of the fluid exactly as it is written insisde the RGP |
September 8, 2016, 22:19 |
Lauren Blanchette
Rep Power: 10 |
I am trying to create a RGP table for sCO2 as well to use in CFX. For this I am creating metastable state tables in which gas properties go into the liquid region. I have created the table but when I try to solve I receive an error stating "Encountered problem reading superheat data". I have gone off of the .rgp file attached to this thread but the only thing that I do not understand is how the saturation temperature and property dependent on the pressure was created at the end of each superheat table. Can anyone explain the way they got there values within the table? Most of my properties are beyond the critical point and thus they do not return a saturation temperature with the known pressure. Any help would be greatly appreciated. Thanks, Lauren |
July 22, 2018, 04:03 |
#5 | |
Yafei Li
Rep Power: 7 |
How to define the Liquid property in the RGP file. Can you give me an example. |
September 14, 2022, 04:31 |
CFX error RGP file for supercritical CO2
ANTALYA
Rep Power: 8 |
Hi, I have been trying to import the RGP file for supercritical CO2 to Ansys CFX. But I met one problem with CFX-solver as follows:
Thank you for your recommendations. Regards. +--------------------------------------------------------------------+ | Buoyancy Reference Information | +--------------------------------------------------------------------+ Domain Group: Default Domain Buoyancy has been activated. The absolute pressure will include hydrostatic pressure contribution, using the following reference coordinates: (-5.44926E-17, 6.31409E-20, 3.00000E-04). Fatal bounds error detected --------------------------- Variable: Thermal Conductivity Locale : Default Domain +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = LVAR CDTYPE = INTR ISIZE = 140 CRESLT = OLD Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
September 14, 2022, 06:39 |
Rep Power: 143 |
The error message says exactly what is going on.
The first section is a comment about how it is setting up the buoyancy calculation. You should read this and check that it is doing the correct thing. This is not an error or warning, just a message. The second bit says there is a bounds error on thermal conductivity. This usually means the pressure or temperature has gone outside of the range of your material properties table. This table may have been defined by your RGP file or it could have come form elsewhere. Either way, the simulation went outside the range you defined. This might mean a bit of the simulation exceeds the range you defined (so you need to extend the range to cover the entire actual range) or your simulation has some numerical problems leading to non-physical values. Maybe it will converge and come good after a while, or maybe it will diverge.
September 14, 2022, 15:57 |
Erik
Rep Power: 23 |
What temperature and pressure are you at?
Are you using the liquid or vapor property tables from your .rgp file? My guess is you may be using the wrong phase, hence variables are out of range in that table. |
September 15, 2022, 06:29 |
#9 | |
ANTALYA
Rep Power: 8 |
September 15, 2022, 06:34 |
#10 | |
ANTALYA
Rep Power: 8 |
$$$$HEADER $$$CO2 1 $$PARAM 26 DESCRIPTION CO2 (LIQUID) NAME CO2 INDEX CO2 DATABASE NIST PROPERTY DATABASE MODEL 3 UNITS 1 PMIN_SUPERHEAT 7494582.6347656 PMAX_SUPERHEAT 8494319.9687500 TMIN_SUPERHEAT 250.0000066 TMAX_SUPERHEAT 750.0000199 TMIN_SATURATION 0.0000000 TMAX_SATURATION 304.1282000 P_CRITICAL 7377300.0000000 P_TRIPLE 517964.3433553 T_CRITICAL 304.1282000 T_TRIPLE 216.5920000 GAS_CONSTANT 188.9240578 TABLE_1 800 800 TABLE_2 800 800 TABLE_3 800 800 TABLE_4 800 800 TABLE_5 800 800 TABLE_6 800 800 TABLE_7 800 800 TABLE_8 800 800 TABLE_9 800 800 $$$CO2VAP 1 $$PARAM 26 DESCRIPTION CO2 (VAPOR) NAME CO2VAP INDEX CO2VAP DATABASE NIST PROPERTY DATABASE MODEL 3 UNITS 1 PMIN_SUPERHEAT 7494582.6347656 PMAX_SUPERHEAT 8494319.9687500 TMIN_SUPERHEAT 250.0000066 TMAX_SUPERHEAT 750.0000199 TMIN_SATURATION 250.0000066 TMAX_SATURATION 750.0000199 P_CRITICAL 7377300.0000000 P_TRIPLE 517964.3433553 T_CRITICAL 304.1282000 T_TRIPLE 216.5920000 GAS_CONSTANT 188.9240578 TABLE_1 800 800 TABLE_2 800 800 TABLE_3 800 800 TABLE_4 800 800 TABLE_5 800 800 TABLE_6 800 800 TABLE_7 800 800 TABLE_8 800 800 TABLE_9 800 800 $$$$DATA $$$CO2 1 $$PARAM 26 DESCRIPTION CO2 (LIQUID) NAME CO2 INDEX CO2 DATABASE NIST PROPERTY DATABASE MODEL 3 UNITS 1 PMIN_SUPERHEAT 7494582.6347656 PMAX_SUPERHEAT 8494319.9687500 TMIN_SUPERHEAT 250.0000066 TMAX_SUPERHEAT 750.0000199 TMIN_SATURATION 250.0000066 TMAX_SATURATION 750.0000199 P_CRITICAL 7377300.0000000 P_TRIPLE 517964.3433553 T_CRITICAL 304.1282000 T_TRIPLE 216.5920000 GAS_CONSTANT 188.9240578 TABLE_1 800 800 TABLE_2 800 800 TABLE_3 800 800 TABLE_4 800 800 TABLE_5 800 800 TABLE_6 800 800 TABLE_7 800 800 TABLE_8 800 800 TABLE_9 800 800 $$SUPER_TABLE values are continuing. |
September 15, 2022, 07:05 |
#11 | |
Rep Power: 143 |
* save a results file just before the error and have a look at it. Is it physically realistic? * Look at the convergence. Is it converging? If it appears to be converging and realistic then you might need to increase the range. If it is not converging then you need to fix the convergence problem. If it is not realistic then you need to look at your simulation to see if it is correctly set up.
September 15, 2022, 14:46 |
#12 |
Erik
Rep Power: 23 |
The fluid is using either one table or the other based on the the name you set them to (CO2 or CO2VAP) which are the names of the liquid and vapor tables. They are two different phases, and if you specified the table name to be "CO2" then you are using the liquid table, not the vapor table. In CFX, in the material properties, you have to use component name "CO2VAP" to use the vapor table. At 80 bar, you are supercritical, therefore you should be using only the vapor table, not the liquid table.
As I said in my last post: "My guess is you may be using the wrong phase, hence variables are out of range in that table." Which I'm now more confident in. You are using the liquid table, not the vapor table as you should. So of course, data is out of range of the liquid table at 80 bar since CO2 is "vapor" above 73 bar. |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
