using RNG k-e
Like Tree5Likes
Old   July 21, 2016, 03:55
Default using RNG k-e
zryan civil is on a distinguished road
I used k-e for free surface model the result was converged, but for the same model (same mesh size time scale .... ) I used RNG k-e (for comparison)the simulation does not reach to convergence after 1200 iteration. can anyone tell me the reasons
thanks
zryan civil is offline   Reply With Quote
Old   July 22, 2016, 01:48
have anyone any suggestion for above problem ??????, please
Old   July 22, 2016, 05:42
K-e and RNG k-e turbulence models are very similar. If this change in your model makes a difference then you model is obviously on the verge of being numerically unstable.
Old   July 22, 2016, 06:34
but I do not change anything in my model, only turbulence model from k-e to RNG k-e, what should I do to the model in order become convergence with RNG K-e??? I reduced time scale but It does not reach convergence
Old   July 22, 2016, 06:42
The standard things to improve numerical stability: Double precision numerics, better mesh quality, smaller time step, better initial condition.
zryan civil likes this.
Old   July 22, 2016, 07:28
but I did all above parameters for simulation by k-e and successfully reach convergence but for RNG k-e does not reach
Old   July 22, 2016, 07:57
Let me repeat post #3:
Old   July 22, 2016, 15:13
as I understood from your post , (if changing turbulence model from RNG k-e to standard k-e, makes the solver numericaly unstable then some parameters should be changed such as (time scale, mesh quality ...)) is that Right??
Old   July 22, 2016, 18:36
Yes, correct.
But the point I am really trying to say is that your simulation is very unstable anyway. So anything you do to make the RNG simulation converge will help the k-e simulation as well.
Old   July 23, 2016, 10:25
Yes, correct.
After changing mesh to coarse to hide vortex shedding in order to become convergence and increasing time scale the results are, mass flow rate become constant, but highly fluctuation observed in v,u,w equations, I used supercritical B.C at outlet, initial conditions include velocity, pressure and (air and water VoF)
https://drive.google.com/open?id=0B3...0pNRmtnemtQR00
https://drive.google.com/open?id=0B3...W5IUmp1dkJHQTg
while previous residual for fine mesh with lower time step are
https://drive.google.com/open?id=0B3...HctaFA1TkwxeUE
Old   July 24, 2016, 07:38
This is normal. But note that your results have probably reduced in accuracy significantly by coarsening the mesh.
In my experience many free surface flow simulations require a transient solution to obtain convergence. This is because surface waves have very low dissipation and they can be resolved in a transient simulation but cause havoc with convergence in steady state simulations. So have you tried a transient simulation? You should be able to get that to converge even with the fine mesh. But it will take significantly longer to run.
Old   July 24, 2016, 13:32
I did sensitivity analysis for choosing mesh size, turbulent model, for this reason I used k-e and RNGk-e and compare their result, the third is the comparison between steady and transient simulation type for this reason I wan to simulate with steady stat, yes for transient I want for time step use 1- adaptive time step with 5 loop coeff. 2- Strouhal frequency (fst=St D/V), from this formula strouhal number (St) can be find, time step = St/5, which of them are better???
note: 1-adaptive time step need higher computational time, than specifying time step value, 2-I saw many researches in free surface flow performed by CFX using steady state analysis type !!
Old   July 24, 2016, 20:45
For transient simulations I recommend adaptive with 3-5 coeff loops. You can use time step formula you like, but you need to check the time step sensitivity.
If other researchers have got this model to converge steady state then have a look at what they have done and try to figure out why they get it working and you can't.
Old   July 28, 2016, 04:36
thanks
If I used time step according to equation, how can I check my result does reach convergence
Old   July 28, 2016, 07:06
By defining a convergence criteria and seeing if it is achieved.
Old   July 28, 2016, 15:46
ok, I defined residual (10-4), and imbalances 0.01, and a monitor point at outlet to monitor mass flow rate (or any interest variable), if the a above criterion are met, so the convergence was achieved. is it right?
Old   July 28, 2016, 18:35
Yes, the convergence tolerance you defined has been achieved. But is the tolerance you defined sufficient to give an accurate enough result? That is an important question as well.
Old   August 4, 2016, 07:14
according to residuals and imbalances the results appear that reached convergence, but Courant No. is high (RMS Courant no. = 15 , MAX Courant no. = 286) is the a problem?
Old   August 4, 2016, 07:31
Do a sensitivity analysis on your time step size and find out.
Old   August 5, 2016, 03:10
I tested three time step (0.05, 0.04, 0.03), the results of (0.03, 0.04) is near to each other and courant No. reduced to 10 at time step 0.03. is that enough?
RNG k-epsilon model implementation romant OpenFOAM Running, Solving & CFD 2 June 20, 2018 08:33
why RNG k-e is better & what does RNG really mean? Bonnie White FLUENT 1 August 8, 2006 09:14
HELP!! Prandtl numbers in RNG k-e turbulence model maoasis FLUENT 0 April 24, 2006 10:51
rng les zxaar FLUENT 0 May 18, 2005 01:16
RNG with Schemit number zwdi FLUENT 0 August 2, 2004 11:54
