Is it possible to find position of separation point in CFX? |
September 28, 2016, 13:19 |
Aja
Rep Power: 14 |
The following figure is tangential velocity contour in a turbine. Now i want to find exactly position of separation point in that. Is it possible? How? Thanks. Last edited by aja1345; October 3, 2016 at 16:05. |
September 29, 2016, 01:04 |
urosgrivc
Rep Power: 11 |
If you plot vectors of velocity you are going to find that vectors turn in the other direction (forward) near the wall, Than you can pinpoint where backward facing flow and forward facing flow meet eachother and some kind of stagnation point with almost no welocity is present this is the flow seperation point.
That is one way of doing it, some other way includes inverse pressure gradients but I am not familiar with those. |
September 29, 2016, 01:23 |
Lance
Rep Power: 22 |
Or check the wall shear stress component in the flow direction on the wall.
September 29, 2016, 02:05 |
urosgrivc
Rep Power: 11 |
Hi Lance, that is a good one I havent thought about that one, thanks.
It probably reaches 0 or some lowest walue where seperation ocures, corect? |
September 29, 2016, 03:48 |
Aja
Rep Power: 14 |
Thanks.
I think that there are not wall shear stress components in CFX! But there are wall shear x,y,z in CFX. Where does wall shear stress components in CFX? I used turbo charts for this case as follows: Is it correct? The turbine rotates in direction of -X ( according to right hand rule, it rotates in direction of +Y) as follows and inlet velocity is in direction of Y. According above explanations, how can i find separation point in my case exactly? Last edited by aja1345; October 3, 2016 at 16:05. |
September 29, 2016, 05:20 |
Aja
Rep Power: 14 |
Separation occurs theoretically at the point where is zero. So, if i have a graph, i can find this point easily. How can i plot graph in CFX?
September 29, 2016, 06:12 |
Aja
Rep Power: 14 |
Hi again,
I plotted Velocity .Gradient as follows: Is it correct for separation point? Last edited by aja1345; October 3, 2016 at 16:06. |
September 29, 2016, 06:17 |
Aja
Rep Power: 14 |
i have to identify point corresponding to the condition d=0. This comes from shear stress value being zero at that point. Therefore, Is above post correct?
September 29, 2016, 06:22 |
#9 |
Aja
Rep Power: 14 |
In the following figure, There is not zero value in Velocity .Gradient but there is lowest value near to zero.....in this position, is there separation point?
September 29, 2016, 07:53 |
#10 |
Aja
Rep Power: 14 |
I was wrong!
I think that i should apply velocity gradient . The plot is as follows: This plot is clearer! and separation point is clear in plot. separation point is near to 0.m. Is it correct? Last edited by aja1345; October 3, 2016 at 16:07. |
September 30, 2016, 04:58 |
#11 |
Aja
Rep Power: 14 |
No-one guide?
September 30, 2016, 07:18 |
#12 |
urosgrivc
Rep Power: 11 |
Where is the problem and why are you posting so meny graphs here on this thread? I had a feeling that you were talking to yourself or diferent topic in the last 7 posts.
Why dont you listen to Lance and me. If you want to pinpoint the seperation point you can do what we told you to, days ago. Lances (shear) aproach and my (vector) aproach both are shown in these three figures: 1 http://https://drive.google.com/open?id=0Bw9ueWZA9k_QOGpVS0tHMDZldW8 2 zoomed in - http://https://drive.google.com/open?id=0Bw9ueWZA9k_QcTd2eWNoQU94eDA 3 zoomed in further - http://https://drive.google.com/open?id=0Bw9ueWZA9k_QUXVTTE9TV2tZTzQ Both aproaches show wery good agrement with eachother. |
September 30, 2016, 07:47 |
#13 |
Aja
Rep Power: 14 |
Hi urosgrivc,
Thanks for your answers, but i don't want to discomfiture you. In fact, I want to know that approach of post 10 is OK or not? I want to learn different approach in this case, urosgrivc. I would like all of the ideas discussed here. however, I am grateful that allocating your time for me. Thanks. |
October 4, 2016, 04:41 |
#14 |
Rep Power: 143 |
And a further complication is that separation points can be exactly defined in 2d flows but there is not a general definition of separation point (or even separation line) in 3d flows. If your flow is 3d you might be able to define something, but it will not be universal for all flows.
How to output more digits after the decimal point in CFX post | Anna Tian | CFX | 7 | August 13, 2013 19:23 |
[Commercial meshers] Converting fluent mesh to foam | sivakumar | OpenFOAM Meshing & Mesh Conversion | 11 | April 30, 2013 09:29 |
How the way I can find efficiency of centrifugal pump from CFX | tttonggg | CFX | 2 | March 25, 2012 06:29 |
How to find the separation point in fluent | caohan | FLUENT | 3 | April 8, 2010 13:48 |
Separation Point over a NACA 0012 | Franny | Main CFD Forum | 3 | March 22, 2007 14:49 |
