Modelling acoustic resonance with deforming mesh - PEEKI error |
October 1, 2016, 08:49 |
Christopher G
Hello everyone,
I'm trying to get an acoustic resonance of air in tube, closed at one side. I'm doing it using deforming mesh (periodic displacement option). I use sweepable mesh (since I've been told I need to use this, because of possible negative volume errors), I set up the model - in order to decrease computational space I use 1/4 of air cylinder, and use symmetry boundary twice - and set up deforming wall at one side of cylinder (so I put the deformation of 1mm in X direction only, proper frequency, phase angle - I need to obtain sinusoidal oscillation). Mesh movement on all other walls of the cylinder is set up as unspecified. When I start computations, only 0th iteration is performed, and then I get this error message: Details of error:- ---------------- Error detected by routine PEEKI CDANAM = MESHDISP/IEQN CRESLT = NONE Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/EQUATIONS ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR I tried to find similar case (error) on this forum, but I failed. Does anyone know what is going on? I'd appreciate any help.
Best regards, Chris G |
October 3, 2016, 08:32 |
urosgrivc
Rep Power: 11 |
I hawe a filing that it has something to do with phase angle or time steping.
October 4, 2016, 04:48 |
Rep Power: 143 |
I have never used the periodic displacement option you used. I always define my own displacement function and this approach has always worked for me.
The error suggests you have missed setting a required parameter in the mesh displacement set up somewhere, but gives you no clues as to which parameter is missing. |
deforming mesh, error memerr, error peeki, resonance |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
