October 3, 2016, 23:09 |
problem with dispersed solid model and exp
Rep Power: 11 |
hi
I'm modeling a tank that contain water and some solid particles. I'm using dispersed solid model to simulate solid particles. i want to record the volume fraction or mass concentration of particles at outlet. so i used the following exp: ave(phase1.vf )@outlet after some time...the tank is empty of solid particles but the exp give some bad result and it shows that solids are crossing the outlet but there is no solid in tank ( I did simulation with very qualified mesh but it happened again.i used dp but not helped... can anyboidy help me whats wrong with this expression ? i think the exp is wrong...please give me some ideas. thanks |
October 4, 2016, 04:51 |
Rep Power: 143 |
Note the averaging function you used is just an arithmetic average of all the faces, regardless of size. You probably want to use areaAve() instead so you get an area weighted average.
But I cannot help you with your actual question at the moment. It sounds like a setup problem. |
October 6, 2016, 11:23 |
#3 | |
Rep Power: 11 |
Hi ghorrocks. thank you i also used areaAve() and the results were same..now I use massflowAve() and i'm waiting for the results... some information of simulation: particle diameter : 30 micron particle density :1900 kg m^-3 using buoyancy turbulence model: k-e RNG (Homo) isothermal drag coef: 0.44 (default) BC: 1 inlet-1 outlet-2 symmetric-walls.. and something that make me confused in results : for the walls..the contour show a 0.5 volume fraction for solid just at one point on wall (after the whole particle left the tank) ..I used very very refined mesh with inflation...max of yplus is 3 ... |
October 9, 2016, 07:04 |
Rep Power: 143 |
Is this a Eularian or Lagrangian model?
Please shows some images of what you are modelling and the results you are getting. Also show why it is wrong, and what you expect to get. |
Eulerian-Granular Mass transfer UDF problem | therandomestname | FLUENT | 1 | April 25, 2011 17:58 |
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation | Pathak | FLOW-3D | 0 | August 24, 2009 06:34 |
