October 10, 2016, 23:53 |
Heat Exchange
I need to set up a solar heat exchange. I have a heat box with glass cover. A pipe runs through the box to be heated by solar energy. Water is to be pumped through the pipe to extract the heat. How do I set this up in Ansys CFX?
October 11, 2016, 05:24 |
Rep Power: 143 |
The first thing to work out is to establish what you are trying to learn from this model. What will a simulation show you so you can understand it better? What is the problem with the design? Or are you trying to optimise the design? Or something else?
Once you know what you want to learn you then need to think about what the important physics is for the effect you expect to see. One you answer these questions we might be able to help you. |
October 11, 2016, 08:36 |
I want to simulate the effect of the fluid flow rate on the amount of heat absorbed from the heat box. Also, I want to simulate the effect of using different fluids for the systems. These simulations at heat flux of 200 -1,000 W/m2
October 11, 2016, 17:57 |
Rep Power: 143 |
In that case it sounds like a model of the fluid system with a heat load applied to the wall boundary would model that. Then there is no need to model the solar radiation or anything external to the pipe - which simplifies things a lot.
October 11, 2016, 21:15 |
qihongming
Rep Power: 17 |
this case is very silimiar to my thread:
http://www.cfd-online.com/Forums/cfx...tml#post621110 I also want to know results |
Energy residual and total heat exchange fluctuation | nirmal_singh | STAR-CCM+ | 0 | August 17, 2016 04:41 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Problem of heat balance in Coal Boiler simulation | DG | FLUENT | 9 | December 25, 2008 20:57 |
Multi phase heat exchange simulation. | JP | CFX | 1 | May 26, 2008 05:22 |
heat exchange | Silvia | FLUENT | 0 | August 19, 2005 10:34 |
