Sudden increase the residual of Maxwell's equations |
October 13, 2016, 03:22 |
Zhen
Rep Power: 9 |
Hi guys,
I am simulating free burning arc in open air. My model can run the DC arc current of 5 kA and arcing time 10 ms. But for arc time 5 kA and 100 ms, it can run another 100 ms after the arcing time and then it crashes. After I check the out file, I find there is an sudden increase of the residual of Maxwell's equaions. It is understandable that after the arcing time, there is no more current input and any other energy input, therefore the Maxwell's equations will stops calculation gradually. To prevent the fault extrapolation, I add a step function to the current input to make sure that the current input stays 0 after the arcing time. I also changed the timestep from 1e-3 and 1e-4 but still crash at the same time. Does anyone have some solution for that? Thank you Timestep: 1e-4 Adaptive Timestepping Information | ---------------------------------------------------------------------- | Direction | Ratio | Last Value | Next Value | RMS Co | Max Co | +----------------+-------+------------+------------+--------+--------+ | Unchanged | 1.000 | 1.0000E-04 | 1.0000E-04 | 0.08 | 0.28 | +----------------+-------+------------+------------+--------+--------+ ================================================== ==================== TIME STEP = 4031 SIMULATION TIME = 2.0627E-01 CPU SECONDS = 1.015E+07 (THIS RUN: 1071 1.0139E-01 2.346E+06) ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 1 CPU SECONDS = 2.346E+06 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.89 | 6.9E-05 | 8.2E-04 | 4.7E-01 ok| | V-Mom | 0.92 | 6.7E-05 | 1.1E-03 | 4.8E-01 ok| | W-Mom | 0.85 | 1.9E-04 | 8.8E-04 | 4.7E-01 ok| | P-Mass | 1.00 | 2.1E-03 | 1.6E-02 | 12.5 7.3E-02 OK| +----------------------+------+---------+---------+------------------+ | Ax-Mag-Fluid Domain | 0.00 | 5.4-137 | 5.4E-70 | 0.0E+00 OK| | Ay-Mag-Fluid Domain | 0.00 | 7.8-137 | 8.7E-70 | 0.0E+00 OK| | Az-Mag-Fluid Domain | 0.00 | 1.4-136 | 8.5E-70 | 0.0E+00 OK| | Ax-Mag-Solid Domain | 0.00 | 1.5-136 | 1.1E-69 | 0.0E+00 OK| | Ay-Mag-Solid Domain | 0.00 | 2.1-136 | 1.2E-69 | 0.0E+00 OK| | Az-Mag-Solid Domain | 0.00 | 2.7-136 | 1.2E-69 | 0.0E+00 OK| | Ax-Mag-Solid Domain | 0.00 | 3.6E-72 | 4.1E-71 | 0.0E+00 OK| | Ay-Mag-Solid Domain | 0.00 | 5.0E-72 | 6.8E-71 | 0.0E+00 OK| | Az-Mag-Solid Domain | 0.00 | 2.3E-71 | 2.5E-70 | 5.2 0.0E+00 OK| +----------------------+------+---------+---------+------------------+ | E-Pot-Fluid Domain | 0.00 | 2.3E-91 | 1.7E-89 | 0.0E+00 OK| | E-Pot-Solid Domain E | 0.00 | 9.1-105 | 1.8-103 | 0.0E+00 OK| | E-Pot-Solid Domain E | 0.00 | 2.1-106 | 4.5-105 | 5.4 0.0E+00 OK| +----------------------+------+---------+---------+------------------+ | H-Energy | 1.00 | 4.7E-04 | 7.0E-03 | 2.4E-05 OK| | T-Energy-Solid Domai | 1.00 | 1.2E-05 | 4.1E-04 | 2.4E-05 OK| | T-Energy-Solid Domai | 1.00 | 5.5E-05 | 3.3E-04 | 5.5 2.4E-05 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 1.00 | 2.5E-04 | 2.7E-03 | 5.5 4.1E-05 OK| | E-Diss.K | 1.00 | 5.0E-05 | 1.2E-03 | 10.5 5.9E-07 OK| +----------------------+------+---------+---------+------------------+ ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 2 CPU SECONDS = 2.346E+06 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.35 | 9.3E-05 | 2.6E-03 | 5.5E-01 ok| | V-Mom | 1.35 | 9.0E-05 | 2.3E-03 | 5.8E-01 ok| | W-Mom | 0.51 | 9.8E-05 | 3.6E-03 | 5.2E-01 ok| | P-Mass | 2.70 | 5.7E-03 | 5.6E-02 | 12.5 7.6E-02 OK| +----------------------+------+---------+---------+------------------+ | Ax-Mag-Fluid Domain | 0.00 | 2.0-134 | 8.8E-69 | 0.0E+00 OK| | Ay-Mag-Fluid Domain | 0.00 | 2.2-134 | 1.3E-68 | 0.0E+00 OK| | Az-Mag-Fluid Domain | 0.00 | 6.9-134 | 1.6E-68 | 0.0E+00 OK| | Ax-Mag-Solid Domain | 0.00 | 1.7-134 | 3.4E-69 | 0.0E+00 OK| | Ay-Mag-Solid Domain | 0.00 | 2.2-134 | 6.8E-69 | 0.0E+00 OK| | Az-Mag-Solid Domain | 0.00 | 2.6-134 | 6.6E-69 | 0.0E+00 OK| | Ax-Mag-Solid Domain | 0.00 | 2.1E-71 | 1.3E-70 | 0.0E+00 OK| | Ay-Mag-Solid Domain | 0.00 | 2.8E-71 | 1.7E-70 | 0.0E+00 OK| | Az-Mag-Solid Domain | 0.00 | 1.9E-70 | 8.7E-70 | 5.2 0.0E+00 OK| +----------------------+------+---------+---------+------------------+ | E-Pot-Fluid Domain | 0.00 | 8.2E-78 | 7.6E-76 | 0.0E+00 OK| | E-Pot-Solid Domain E | 0.00 | 6.2E-91 | 4.4E-90 | 0.0E+00 OK| | E-Pot-Solid Domain E | 0.00 | 6.6E-78 | 7.7E-77 | 5.4 0.0E+00 OK| +----------------------+------+---------+---------+------------------+ | H-Energy | 0.31 | 1.5E-04 | 6.1E-03 | 1.1E-05 OK| | T-Energy-Solid Domai | 0.50 | 5.8E-06 | 2.0E-04 | 1.1E-05 OK| | T-Energy-Solid Domai | 0.50 | 2.7E-05 | 1.6E-04 | 5.5 1.1E-05 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.49 | 1.3E-04 | 2.7E-03 | 5.5 3.0E-05 OK| | E-Diss.K | 1.24 | 6.2E-05 | 2.3E-03 | 10.5 1.7E-06 OK| +----------------------+------+---------+---------+------------------+ ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 3 CPU SECONDS = 2.347E+06 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.94 | 8.7E-05 | 2.3E-03 | 2.9E-01 ok| | V-Mom | 1.07 | 9.7E-05 | 3.4E-03 | 2.8E-01 ok| | W-Mom | 0.95 | 9.4E-05 | 4.7E-03 | 2.5E-01 ok| | P-Mass | 0.62 | 3.5E-03 | 6.4E-02 | 12.5 6.0E-02 OK| +----------------------+------+---------+---------+------------------+ | Ax-Mag-Fluid Domain | 0.00 | 3.8E-02 | 1.5E-02 | 3.9E-02 OK| | Ay-Mag-Fluid Domain | 0.00 | 4.1E-02 | 2.1E-02 | 5.8E-02 OK| | Az-Mag-Fluid Domain | 0.00 | 7.0E-02 | 2.7E-02 | 7.8E-02 OK| | Ax-Mag-Solid Domain | 0.00 | 2.4E-02 | 7.0E-03 | 3.9E-02 OK| | Ay-Mag-Solid Domain | 0.00 | 3.1E-02 | 1.1E-02 | 5.8E-02 OK| | Az-Mag-Solid Domain | 0.00 | 2.9E-02 | 8.7E-03 | 7.8E-02 OK| | Ax-Mag-Solid Domain | 0.00 | 5.4E-05 | 5.6E-04 | 3.9E-02 OK| | Ay-Mag-Solid Domain | 0.00 | 6.9E-05 | 5.8E-04 | 5.8E-02 OK| | Az-Mag-Solid Domain | 0.00 | 6.4E-04 | 2.4E-03 | 30.5 7.8E-02 OK| +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255. No results file has been created. | +--------------------------------------------------------------------+ Timestep:1e-3 Adaptive Timestepping Information | ---------------------------------------------------------------------- | Direction | Ratio | Last Value | Next Value | RMS Co | Max Co | +----------------+-------+------------+------------+--------+--------+ | Decreasing | 0.800 | 1.0000E-03 | 8.0000E-04 | 0.85 | 2.88 | +----------------+-------+------------+------------+--------+--------+ ================================================== ==================== TIME STEP = 3158 SIMULATION TIME = 2.0626E-01 CPU SECONDS = 8.342E+06 (THIS RUN: 198 1.0138E-01 5.335E+05) ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 1 CPU SECONDS = 5.335E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.01 | 2.4E-04 | 4.2E-03 | 8.8E-02 OK| | V-Mom | 0.95 | 2.4E-04 | 2.8E-03 | 8.2E-02 OK| | W-Mom | 1.22 | 5.6E-04 | 2.4E-03 | 6.7E-02 OK| | P-Mass | 0.96 | 6.6E-04 | 4.5E-03 | 31.6 8.1E-02 OK| +----------------------+------+---------+---------+------------------+ | Ax-Mag-Fluid Domain | 0.00 | 2.0E-02 | 7.4E-03 | 2.6E-02 OK| | Ay-Mag-Fluid Domain | 0.00 | 1.7E-02 | 8.4E-03 | 4.3E-02 OK| | Az-Mag-Fluid Domain | 0.00 | 8.3E-02 | 1.1E-02 | 9.3E-02 OK| | Ax-Mag-Solid Domain | 0.00 | 6.6E-03 | 3.9E-03 | 2.6E-02 OK| | Ay-Mag-Solid Domain | 0.00 | 1.4E-02 | 7.7E-03 | 4.3E-02 OK| | Az-Mag-Solid Domain | 0.00 | 1.9E-02 | 8.2E-03 | 9.3E-02 OK| | Ax-Mag-Solid Domain | 0.00 | 8.1E-05 | 6.2E-04 | 2.6E-02 OK| | Ay-Mag-Solid Domain | 0.00 | 7.7E-05 | 6.2E-04 | 4.3E-02 OK| | Az-Mag-Solid Domain | 0.00 | 5.1E-04 | 2.3E-03 | 34.7 9.3E-02 OK| +----------------------+------+---------+---------+------------------+ | E-Pot-Fluid Domain | 0.00 | 2.7E-04 | 2.5E-02 | 6.0E+00 F | | E-Pot-Solid Domain E | 0.00 | 1.4E-17 | 1.0E-16 | 6.0E+00 F | | E-Pot-Solid Domain E | 0.00 | 7.9E-05 | 6.0E-04 | 14.3 6.0E+00 F | +----------------------+------+---------+---------+------------------+ | H-Energy | 0.99 | 2.1E-03 | 5.7E-02 | 2.2E-03 OK| | T-Energy-Solid Domai | 0.87 | 9.9E-05 | 3.5E-03 | 2.2E-03 OK| | T-Energy-Solid Domai | 0.89 | 4.2E-04 | 2.6E-03 | 5.5 2.2E-03 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.98 | 9.7E-04 | 1.6E-02 | 5.5 4.7E-03 OK| | E-Diss.K | 0.89 | 1.3E-03 | 6.3E-02 | 10.6 1.2E-03 OK| +----------------------+------+---------+---------+------------------+ ---------------------------------------------------------------------- COEFFICIENT LOOP ITERATION = 2 CPU SECONDS = 5.338E+05 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 1.56 | 3.8E-04 | 1.7E-02 | 1.2E-01 ok| | V-Mom | 1.61 | 3.8E-04 | 1.8E-02 | 1.1E-01 ok| | W-Mom | 0.79 | 4.4E-04 | 1.5E-02 | 7.2E-02 OK| | P-Mass | 1.09 | 7.2E-04 | 1.3E-02 | 16.3 9.8E-02 OK| +----------------------+------+---------+---------+------------------+ | Ax-Mag-Fluid Domain | 0.95 | 1.9E-02 | 7.4E-03 | 2.4E-02 OK| | Ay-Mag-Fluid Domain | 1.00 | 1.7E-02 | 9.5E-03 | 4.5E-02 OK| | Az-Mag-Fluid Domain | 1.21 | 1.0E-01 | 1.2E-02 | 8.8E-02 OK| | Ax-Mag-Solid Domain | 1.27 | 8.3E-03 | 3.0E-03 | 2.4E-02 OK| | Ay-Mag-Solid Domain | 0.95 | 1.3E-02 | 6.3E-03 | 4.5E-02 OK| | Az-Mag-Solid Domain | 0.73 | 1.4E-02 | 4.9E-03 | 8.8E-02 OK| | Ax-Mag-Solid Domain | 1.02 | 8.3E-05 | 6.7E-04 | 2.4E-02 OK| | Ay-Mag-Solid Domain | 0.92 | 7.1E-05 | 6.1E-04 | 4.5E-02 OK| | Az-Mag-Solid Domain | 0.87 | 4.4E-04 | 2.3E-03 | 38.9 8.8E-02 OK| +----------------------+------+---------+---------+------------------+ +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 2. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. |
October 13, 2016, 05:34 |
Rep Power: 143 |
Have you tried the general tips in the FAQ? http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
October 13, 2016, 06:58 |
Zhen
Rep Power: 9 |
Yes, but I don't think the link provide useful information in my case. Thank you for the link!
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
