October 13, 2016, 22:36 |
Micro class francis turbine
jini
Rep Power: 9 |
Hi dear all. im making simulation for 3kW micro class hydro turbine. in my case
1. components of turbine: spiral case, runner, draft tube. 2. mesh no of nodes 3.5 million near by wall has a prism mesh. 3. domain: steady state single phase /only water/, inlet of spiral case mass flow rate, outlet of turbine average static pressure, between casing and runner and runner and draft tube using general grid interface and frozen rotor interface. shear stress transport model is used performance analysis was done at 0.02m3/s full load dishcarge and rotational speed is 1800rpm. but here something was wrong my efficiency is too high over 90%. how can i improve the simulation? Last edited by etvan; October 14, 2016 at 06:41. |
October 14, 2016, 01:37 |
urosgrivc
Rep Power: 11 |
how can I reduce efficiency? -> hehe I haven't heard that one before
You must improve the simulation <- this is the answer. (stop and think at the end of this post if it helped you) But you did not provide any data for the people that can help you. So I think that nobody is able to answer this question YET. Geometry?, mesh?, domains?, what hawe you already tried?.... There are infinite ways to suimulate a turbine, be more specific. Try to ask a question that a person that doesent know what you are doing can answer, if you want to get an ansver otherwise this is the most help you can get: http://www.cfd-online.com/Forums/sit...tml#post612025 (4) http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
Francis turbine design | ArslanOZCAN | Main CFD Forum | 1 | February 1, 2015 02:26 |
Horizontal Francis Turbine (VOITH) | mukkarum | Main CFD Forum | 4 | November 29, 2012 17:56 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Francis Turbine | mukkarum | Main CFD Forum | 2 | October 14, 2002 00:58 |
